Hello
I’m stuck on a problem either I don’t understand or I discovered a bug, I’ll explain
here is the code in question
uint8_t send_2C_clear[7] = {0xB8, 0x13, 0xF7, 0x03, 0x2C, 0xF0, 0x04}; //
K_Line.envoie(send_2C_clear, 7);
bool k_Line::envoie(uint8_t data_send[],uint8_t len)
if (Envoie == true)
Serial.println("ENVOIEEE");
data_len=0;
data_len = len;
Serial.print("len = ");
Serial.println(len);
data_send[len] = checksum(len, data_send); // demande de checksum Y = resultat du checksum
Serial.print("checksum = ");
Serial.println(data_send[len],HEX);
Serial.print("envoi = ");
clear();
for (int i = 0; i < len + 1; i++)
Serial2.write(data_send[i]); // envois de la demande ECU
Serial.print(data_send[i],HEX);
Serial.print(",");
Serial.println("");
Envoie = false;
return Envoie;
uint8_t k_Line::checksum(uint8_t length, uint8_t data[])
uint8_t tchecksum;
for (int i = 0; i < length; i++)
tchecksum ^= data[i];
return tchecksum;
void k_Line::clear()
while(Serial2.available()>0) { char inChar = Serial2.read();}
Serial.print =
ENVOIEEE
len = 7
checksum = 87
envoi = A0,13,F7,3,2C,F0,4,87
My question is where does this A0 come from?
This only appears when I do the clear() function
if I remove it I have send = B8,13,F7,3,2C,F0,4,87
impossible to understand why
