Hey everyone, hopefully you can help me resolve this or at least I can bring this to your attention.
I’m on Windows 10 using the PlatformIO plugin (version 212.5080.54).
It seems that if I use an absolute path in lib_extra_dirs, it attempts to be smart in its generation of CMakeListsPrivate.txt by replacing the drive and user directory with $ENV{HOMEDRIVE}$ENV{HOMEPATH}, which then evaluates to include backslashes and breaks cmake. This occurs even if you explicitly use forward slashes in the absolute path.
In platform.ini:
lib_extra_dirs=C:/Users/john_contactci/AppData/Local/Maestro/libs
In the resulting generated CMakeListsPrivate.txt:
FILE(GLOB_RECURSE EXTRA_LIB_SOURCES
${CMAKE_CURRENT_LIST_DIR}/.pio/libdeps/teensy40/*.*
$ENV{HOMEDRIVE}$ENV{HOMEPATH}/AppData/Local/Maestro/libs/*.*
Later on EXTRA_LIB_SOURCES is appended to SRC_LIST:
list(APPEND SRC_LIST ${EXTRA_LIB_SOURCES})
And this results in the following error from CMakeLists.txt:
CMake Error at CMakeLists.txt:33 (add_executable):
Syntax error in cmake code when parsing string
C:\Users\john_contactci/AppData/Local/Maestro/libs/maestro-embedded-config/include/MaestroEmbeddedConfiguration.h
Invalid character escape '\U'.
Due to the backslash in the path.
For reference, line 33 of CMakeLists.txt:
add_executable(Z_DUMMY_TARGET ${SRC_LIST})
Which is why I mention the bit about EXTRA_LIB_SOURCES being appended to SRC_LIST above.
Things I have tried to no avail:
- Defining a
PLATFORMIO_LIB_EXTRA_DIRSenv var, which results in the same problem. - Throwing quotes around the path, which just results in it being treated as a relative path rather than absolute.
- Using backslashes but escaping them (i.e.
\\) in the absolute path.
Any assistance or work around would be greatly appreciated!
Thanks!
– EDIT –
Opened an issue in github here: Bug in CLion for CMakeListsPrivate.txt generation when using lib_extra_dirs in Windows · Issue #4071 · platformio/platformio-core · GitHub
