After trying quite hard and having still no solution, am posting here ;-). The pio CLI (nor Visual Code plugin) does not build on the Raspi4.
My Raspi installation:
Linux raspi4 4.19.97-v8+ #1294 SMP PREEMPT Thu Jan 30 13:27:08 GMT 2020 aarch64 GNU/Linux
(Yes, it’s x64 kernel, as the MS Visual Code is only x64 in their latest releases.)
I’ve installed also the Arduino IDE x32 (x64 doesn’t run) and it runs/builds normally.
I’ve installed the pio onto the Raspi4 - I can run “project init”, “boards” etc. (i.e. it’s running), but can not build.
When freshly installed, it gave me right away errors missing gcc components, which I installed manually:
apt install gcc-avr, binutils-avr, avr-libc
Now another error comes:
avr-g++: error trying to exec ‘cc1plus’: execvp: No such file or directory
Search for it:
find / -name cc1plus
/home/xxx/.platformio/packages/toolchain-atmelavr/libexec/gcc/avr/5.4.0/cc1plus
/home/xxx/Downloads/arduino-1.8.12/hardware/tools/avr/libexec/gcc/avr/7.3.0/cc1plus
/root/.platformio/packages/toolchain-atmelavr/libexec/gcc/avr/5.4.0/cc1plus
/usr/lib/gcc/avr/5.4.0/cc1plus
/usr/lib/gcc/arm-linux-gnueabihf/8/cc1plus
Before this error, there is a warning:
avr-gcc-ar: Cannot find plugin ‘liblto_plugin.so’
Searching for it:
find / -name liblto_plugin.so
/home/xxx/.platformio/packages/toolchain-atmelavr/libexec/gcc/avr/5.4.0/liblto_plugin.so
/home/xxx/Downloads/arduino-1.8.12/hardware/tools/avr/libexec/gcc/avr/7.3.0/liblto_plugin.so
/root/.platformio/packages/toolchain-atmelavr/libexec/gcc/avr/5.4.0/liblto_plugin.so
/usr/lib/gcc/avr/5.4.0/liblto_plugin.so
/usr/lib/gcc/arm-linux-gnueabihf/8/liblto_plugin.so
/usr/lib/bfd-plugins/liblto_plugin.so
I’m not sure if the process break because of iblto_plugin.so (I guess so) or the cc1plus. But before spending even more days into this, I thought this is surely not normal, as it should run just like that !
Any of you able to use pio on the Raspi?
Thank you
