From reading posts here my understanding is that there is a daily crawler that should fetch details of new releases and update the library registry accordingly however that does not seem to have happened here. It has been a couple of days and the new version has still not been picked up.
@maxgerhardt Thanks; using the external git source does indeed work fine. The reason I was asking about the registry update though is that I have a custom component I’m looking to get into PR review for the esphome project which as standard makes use of the registry and I didn’t want to break with that norm. If the crawler is going to get to it eventually then that’s fine, I can wait; I just raised it as it seemed to be taking longer than advertised!
If that PR works it would be weird to me. This updates the Arduino manifest (library.properties) – the crawler will use the library.json if available. And the original architectures declaration is valid in the Arduino manifest (source). Do you have a reference to when that made things work?
