Hello Everyone. I am trying to debug an esp firebeetle using the esp-prog and the PIO debugger while using a custom partition scheme and the esp enters a boot loop every time.
The debugger for the most part (under normal configurations), works fine, stopping on the breakpoints and everything else.
The usb driver is also OK, and i can start the debugging process as normally, so decided to run the following experiments to determine what works and whatnot.
I made a really simple program with a counter on the loop function.
void loop() { delay(delayTime); counter++; }
- ESP-Devkits-V4. No custom partitions. Arduino framework: WORKS
- Firebeetle. No custom partitions. Arduino framework: WORKS
- Firebeetle. board_build.partitions = default.csv. Arduino framework: WORKS
- Firebeetle. board_build.partitions = default_8MB.csv, Arduino framework: DOESNT WORK
- Firebeetle. board_build.partitions = default_16MB.csv, Arduino framework: DOESNT WORK
Partitions are correctly calculated, and they work outside the Debugger.
At this point, i wanted to try if on espidf debugging works. So i made a quick program with an incrementing counter, and gave it a go.
void loop() { vTaskDelay(1000 / portTICK_PERIOD_MS); counter++; }
ESP-Devkits-V4. No custom partitions. IDF framework: WORKS
Firebeetle. No custom partitions. IDF framework: WORKS
Firebeetle. custom partitions with IDF. WORKS
but to get the custom partitions working you need to add these 3 lines lines in the platformio.ini
board_upload.flash_size = 8MB
board_upload.maximum_size = 8388608
Firebeetle. custom partitions 16mb with IDF. WORKS
At this point i went back to the arduino frame work to add the same extra lines on platformio.ini and see, that maybe this was the cause.
But no, it will still get into a boot loop with the debugger active, and the program will crash. Any ideas what may be the issue?
Here is the debug log.
Processing firebeetle32 (platform: espressif32; board: firebeetle32; framework: arduino)
CONFIGURATION:
PLATFORM: Espressif 32 (2.0.0) > FireBeetle-ESP32
- framework-arduinoespressif32 3.10004.201016 (1.0.4)
- tool-openocd-esp32 1.1000.20190709 (10.0)
LDF: Library Dependency Finder ->
Found 26 compatible libraries
Building in debug mode
Retrieving maximum program size .pio\build\firebeetle32\firmware.elf
Checking size .pio\build\firebeetle32\firmware.elf
RAM: [ ] 4.7% (used 15444 bytes from 327680 bytes)
Flash: [= ] 6.5% (used 216865 bytes from 3342336 bytes)
========================= [SUCCESS] Took 1.25 seconds =========================
Reading symbols from c:\Users\g.michalis\source\repos\Esp32_DebuggerTest\.pio\build\firebeetle32\firmware.elf...
done.
PlatformIO Unified Debugger ->
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Detected debug stubs @ 3ffc0cac on core0 of target 'esp32'
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x400E916A (active) APP_CPU: PC=0x400E916A
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x400E916A
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 45 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 100 KB
Info : Auto-detected flash size 16384 KB
Info : Using flash size 16384 KB
Info : Using flash size 104 KB
Info : Using flash size 48 KB
0x400e916a in String::setLen (this=0x0, len=<optimized out>) at C:\Users\g.michalis\.platformio\packages\framework-arduinoespressif32\cores\esp32/WString.h:277
277 inline void setLen(int len) { if (isSSO()) sso.len = len; else ptr.len = len; }
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x40000400
wrote 16384 bytes from file C:/Users/g.michalis/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.722071s (22.158 KiB/s)
** Programming Finished **
** Verify Started **
read 15872 bytes from file C:/Users/g.michalis/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.265294s (58.426 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file c:/Users/g.michalis/source/repos/Esp32_DebuggerTest/.pio/build/firebeetle32/partitions.bin in 0.554576s (7.213 KiB/s)
read 3072 bytes from file c:/Users/g.michalis/source/repos/Esp32_DebuggerTest/.pio/build/firebeetle32/partitions.bin and flash bank 0 at offset 0x00008000 in 0.234374s (12.800 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file C:/Users/g.michalis/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.581463s (13.758 KiB/s)
read 8192 bytes from file C:/Users/g.michalis/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.246372s (32.471 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x5F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x5F).
auto erase enabled
auto erase enabled
wrote 217088 bytes from file c:/Users/g.michalis/source/repos/Esp32_DebuggerTest/.pio/build/firebeetle32/firmware.bin in 2.570163s (82.485 KiB/s)
read 216976 bytes from file c:/Users/g.michalis/source/repos/Esp32_DebuggerTest/.pio/build/firebeetle32/firmware.bin and flash bank 0 at offset 0x00010000 in 0.880646s (240.608 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
Temporary breakpoint 1 at 0x400d0bfc: file src\main.cpp, line 7.
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options ->
Note: automatically using hardware breakpoints for read-only addresses.
Info : xtensa_poll: Target offline
Error: xtensa_poll: Target failure
Warn : target esp32 is not halted (gdb fileio)
Error: FreeRTOS_update_threads not TARGET_HALTED!
Warn : xtensa_read_memory: esp32: target not halted
Error: Could not read FreeRTOS thread count from target
Polling target esp32 failed, trying to reexamine
Remote target] #1 stopped.
0x40000400 in ?? ()
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1111). Workaround: increase "set remotetimeout" in GDB
