I set the bootloader options for my ATtiny84 inside the platformio.ini like described in the docs Atmel AVR — PlatformIO latest documentation. My config:
[env:attiny84]
board = attiny84
upload_protocol = stk500v1
upload_flags =
-P$UPLOAD_PORT
-b$UPLOAD_SPEED
upload_speed = 19200
upload_port = COM3
board_bootloader.file = optiboot/optiboot_attiny84_8000000L.hex
board_bootloader.low_fuses = 0xE2
board_bootloader.high_fuses = 0xDF
board_bootloader.extended_fuses = 0xff
board_bootloader.lock_bits = 0xFF
board_bootloader.unlock_bits = 0xFF
board_build.variant=tinyX4_reverse
When I’m trying to burn the bootloader for my ATtiny84 using
platformio run --target bootloader -v
it fails with “Missing bootloader fuses!” although those are set in the platformio.ini file like shown above:
PS D:\temp\nrftest-attiny84-2> platformio run --target bootloader -v
Processing attiny84 (platform: atmelavr; board: attiny84; framework: arduino; upload_protocol: stk500v1; upload_flags: -P$UPLOAD_PORT, -b$UPLOAD_SPEED; upload_speed: 19200; upload_port: COM3; board_bootloader.file: optiboot/optiboot_attiny84_8000000L.hex; board_bootloader.low_fuses: 0xE2; board_bootloader.high_fuses: 0xDF; board_bootloader.extended_fuses: 0xff; board_bootloader.lock_bits: 0xFF; board_bootloader.unlock_bits: 0xFF; board_build.variant: tinyX4_reverse)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/attiny84.html
PLATFORM: Atmel AVR 2.0.0 > Generic ATtiny84
HARDWARE: ATTINY84 8MHz, 512B RAM, 8KB Flash
PACKAGES: framework-arduino-avr-attiny 1.3.2, toolchain-atmelavr 1.50400.190710 (5.4.0)
Found 9 compatible libraries
Error: Missing bootloader fuses!
==================================================================================== [FAILED] Took 1.64 seconds ====================================================================================
Did is miss something?
Thanks
Markus
