Bodmer TFT_eSPI slider behaviour?
HI All,
I have a TFT touchscreen, with a row of buttons to select different screens.
One of the screens has a TFT_eSPI vertical slider.
Whenever I move the slider, it updates my variable “Slider_Setting”.
So, every time I select that screen, I want the slider to be drawn at that setting.
However, what happens is …
  1. the slider is drawn with the knob at the TOP
  2. then it slides down to the bottom
  3. then it slides back up to my desired value.
This quite a slow process.
The relevant code is …
TFT_eSprite knob = TFT_eSprite(&tft);           // Sprite for the slide knob
SliderWidget s1 = SliderWidget(&tft, &knob);    // Slider 1 widget
Then, for the screen with the slider, I call this …
void Draw_Music_Slider(){
    s1.createSlider(40, 260, TFT_BLUE, TFT_BLACK, V_SLIDER);
    s1.createKnob(60, 25, 5, TFT_GREEN, TFT_BLACK);
    s1.setSliderScale(99, 0, 10);        // MAX value, MIN value, Speed = micro seconds per pixel
    s1.drawSlider(225, 108);
    s1.setSliderPosition(Slider_Setting);
I’ve played with the delay number “Speed” and it doesn’t alter the movement of the slider in steps 1,2 & 3 described above.
Any way to just draw the slider with the knob immediately at my “Slider_Setting” position ?
Thank you.
Trevor
In the example, a parameter is used to configure the slider before it is drawn to the screen:
  // Create a parameter set for the slider
  slider_t param;
  // Slider slot parameters
  param.slotWidth = 9;           // Note: ends of slot will be rounded and anti-aliased
  param.slotLength = 200;        // Length includes rounded ends
  param.slotColor = TFT_BLUE;    // Slot colour
  param.slotBgColor = TFT_BLACK; // Slot background colour for anti-aliasing
  param.orientation = H_SLIDER;  // sets it "true" for horizontal
  // Slider control knob parameters (smooth rounded rectangle)
  param.knobWidth = 15;          // Always along x axis
  param.knobHeight = 25;         // Always along y axis
  param.knobRadius = 5;          // Corner radius
  param.knobColor = TFT_WHITE;   // Anti-aliased with slot backgound colour
  param.knobLineColor = TFT_RED; // Colour of marker line (set to same as knobColor for no line)
  // Slider range and movement speed
  param.sliderLT = 0;            // Left side for horizontal, top for vertical slider
  param.sliderRB = 100;          // Right side for horizontal, bottom for vertical slider
  param.startPosition = 50;      // Start position for control knob
  param.sliderDelay = 0;         // Microseconds per pixel movement delay (0 = no delay)
  // Create slider using parameters and plot at 0,0
  s1.drawSlider(0, 0, param);
Hi Boris,
I originally started off using the parameter method in the example and it seemed to have exactly the same behaviour.
I’ll try again today, just in case I missed something.
Thank you,
Trevor
setSliderPosition calls internally the moveTo function which moves the slider animated.
Using the parameter style should avoid this animation and set the position directly.
Oh I see, I did go through the slider .h and .cpp files and could understand a lot of Bodmer’s thinking, but couldn’t clearly understand some of the flow and some of the functions. A bit above my grade :joy:
I’ll try the parameter method again soon.
Thanks Boris.
Trevor
So, just tried this, based on Bodmer’s example …
// Trev's touch screen Slider widget demo
// from https://github.com/Bodmer/TFT_eWidget
#include "FS.h"
#include <TFT_eSPI.h>
#include <TFT_eWidget.h>           // Widget library
TFT_eSPI tft = TFT_eSPI();
// This is the file name used to store the calibration data
// The SPIFFS file name must start with "/".
#define CALIBRATION_FILE "/TouchCalData2"
// CALIBRATE NOW ??????
// Set REPEAT_CAL to true for first run, or if
// screen rotation is changed.
// Set to false, once calibrated OK.
#define REPEAT_CAL false
// #####     CALIBRATE TOUCH SCREEN       #############
void touch_calibrate() {
  uint16_t calData[5];
  uint8_t calDataOK = 0;
  // check file system exists
  if (!SPIFFS.begin()) {
    Serial.println("formatting file system");
    SPIFFS.format();
    SPIFFS.begin(); }
  // check if calibration file exists and size is correct
  if (SPIFFS.exists(CALIBRATION_FILE)) {
    if (REPEAT_CAL) {
      // Delete if we want to re-calibrate
      SPIFFS.remove(CALIBRATION_FILE);
    } else {
      File f = SPIFFS.open(CALIBRATION_FILE, "r");
      if (f) {
        if (f.readBytes((char *)calData, 14) == 14)
          calDataOK = 1;
        f.close();
  //Touch screen calibration already done OK ############
  if (calDataOK && !REPEAT_CAL) {
    //calibration data valid ----------------------------
    tft.setTouch(calData);
  } else {
    //data not valid so recalibrate ---------------------
    tft.fillScreen(TFT_BLACK);
    tft.setCursor(20, 0);
    tft.setTextFont(2);
    tft.setTextSize(1);
    tft.setTextColor(TFT_WHITE, TFT_BLACK);
    tft.println("Touch corners as indicated");
    tft.setTextFont(1);
    tft.println();
    if (REPEAT_CAL) {
      tft.setTextColor(TFT_RED, TFT_BLACK);
      tft.println("Set REPEAT_CAL to false to stop this running again!");
    tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
    tft.setTextColor(TFT_GREEN, TFT_BLACK);
    tft.println("Calibration complete!");
    // store data -----------------------------------------------------------------
    File f = SPIFFS.open(CALIBRATION_FILE, "w");
    if (f) {
      f.write((const unsigned char *)calData, 14);
      f.close();
// #####     SET UP       #############################
  // Start TFT screen SPI
  tft.begin();
  tft.setRotation(4);
  // Calibrate the touch screen and retrieve the scaling factors
  touch_calibrate();
  // Create a parameter set for a VERTICAL slider on TFT screen at x=225, y=108
  slider_t param;
  param.slotWidth = 40;             // Note: ends of slot will be rounded and anti-aliased
  param.slotLength = 260;           // Length includes rounded ends
  param.orientation = V_SLIDER;     // sets it "false" for vertical
  // Knob details
  param.knobWidth = 60;             // knob width
  param.knobHeight = 25;            // knob height
  param.knobRadius = 5;             // knob corner radius
  param.knobColor = TFT_GREEN;      // Anti-aliased with slot backgound colour
  param.knobLineColor = TFT_WHITE;  // Colour of marker line (set to same as knobColor for no line)
  // Slider range, start position and speed
  param.sliderLT = 99;              // Top of slider value range
  param.sliderRB = 0;               // Bottom of slider value range
  param.startPosition = 20;         // Start position for control knob
  param.sliderDelay = 100;          // Slider speed delay 2000 micro seconds per pixel
  // Draw slider to TFT screen
  s1.drawSlider(225, 108, param);   //Draw to TFT screen at x, y, using parameters
// #####     LOOP - SLIDER TOUCH ???      #############
  static uint32_t scanTime = millis();
  uint16_t t_x = 9999, t_y = 9999; // To store the touch coordinates
  // Scan for touch every 50ms
  if (millis() - scanTime >= 20) {
    // Pressed will be set true if there is a valid touch on the screen
    if( tft.getTouch(&t_x, &t_y, 250) ) {
      if (s1.checkTouch(t_x, t_y)) {
        Serial.print("Slider 2 = "); Serial.println(s1.getSliderPosition());
Initially, I set #define REPEAT_CAL true, to calibrate my screen at tft.setRotation(4);.
I started at param.startPosition = 50; … the slider was drawn with the knob at 50 immediately, plus slider operation was immediately available.
Then I changed to param.startPosition = 20;
Now, each time I start up, the slider is always drawn with the knob at 50 and then animated slowly down to 20.
Only after that is completed, then I can operate the slider.
Lowering to value of param.sliderDelay = 100; doesn’t change the initial animation speed.
Increasing the value slows the animation and makes the slider slower, when I move it.
Changing param.sliderDelay = 0; causes these faults.
  1. Initially, the knob is drawn at 20 and I can move it immediately, but a strange rectangle is drawn beside the bottom of the slider slot.
  2. Moving the slider draws knobs and strange rectangles all over the slot
Apologies for the rubbish pictures, but the TFT is very bright and blinds my phone camera.
So, I’m still a bit stuck. I can work with the slider at a delay of 100, which doesn’t take too long to setup.
I really wanted to make the slider move much slower, but that takes a long time to set itself up.
I’ve obviously missed something in this sketch, but I cannot see what or where ?
Thank you.
Trevor
