Is anyone aware of a board definition that would match the hardware for ESP32 Terminal- 3.5 Inch 480x320 TFT Capacitive Touch Display(RGB) with Chip ILI9488 ??
Thanks!
Craig
Thanks!
Craig
Their official docs say to treat it as a āESP32S3 Dev Moduleā in the Arduino IDE with Flash mode QIO, 80MHz, Flash size 16MB and OPI PSRAM. Thus this should 100% match what was already said before at Enable OPI PSRAM and 16MB QIO80MHz of FLASH - #2 by maxgerhardt.
Thanks much @maxgerhardt
To save platformio users time, this worked for me:
[env:base]
board = esp32-s3-devkitc-1
build_flags = -DBOARD_HAS_PSRAM
board_build.arduino.memory_type = qio_opi
board_build.f_flash = 80000000L
board_build.flash_mode = qio
; 16MB
board_upload.flash_size = 16MB
The Elecrow ESP32 3.5" SPI terminal (DLC35020S) is small but packed with features! Is it a good choice for your robot?
Thank you!
Can you share some code example for GUI usage? It can help as a jumpstart.
The LVGL project has a number of demo applications you can try. https://github.com/lvgl/lvgl/tree/master/demos
trying to run one of the tutorial demos to run under platformIO 5" display.
the Elegrow descriptin for platformIO is a Maze, too much dependecies
