I’m building an ESP32 project that uses a signed application. The ESPIDF framework wants the file signature_verification_key.bin.S
file in the bootloader
directory off the project root. I have no problem actually creating the .S file, but it’s placing it in the ./.pio/build/esp32-gateway
directory, rather than in ./.pio/build/esp32-gateway/bootloader
. If there’s a way to tell embed_txtfiles
where to put the output file, I’m missing it.
If I manually copy signature_verification_key.bin.S
into ./.pio/build/esp32-gateway/bootloader
and run pio run
again, it finishes building and links just fine.
Is there any work around for this? I have no control over what ESPIDF wants as far as where the file is located. It’s buried deep somewhere in the framework CMake files.
platformio.ini:
[platformio]
default_envs = esp32-gateway
[env:esp32-gateway]
board = esp32-gateway
framework = espidf
board_build.partitions = partitions.csv
board_build.embed_txtfiles =
server_certs/ca_cert.pem
bootloader/signature_verification_key.bin
[env:esp32-poe]
board = esp32-poe
framework = espidf
Building:
$ pio run
Processing esp32-gateway (platform: espressif32; board: esp32-gateway; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-gateway.html
PLATFORM: Espressif 32 (3.5.0+sha.d93c9ef) > OLIMEX ESP32-GATEWAY
- framework-espidf 3.40302.0 (4.3.2)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-riscv32-esp 8.4.0+2021r2-patch2
- toolchain-xtensa-esp32 8.4.0+2021r2-patch2
- toolchain-xtensa-esp32s2 8.4.0+2021r2-patch2
Generating assembly for certificate bundle...
Found 0 compatible libraries
Generating assembly for .pio/build/esp32-gateway/ca_cert.pem.S
Generating assembly for .pio/build/esp32-gateway/signature_verification_key.bin.S
Compiling .pio/build/esp32-gateway/src/ethernet.o
Compiling .pio/build/esp32-gateway/src/fwota.o
Compiling .pio/build/esp32-gateway/bootloader/bootloader_support/src/esp32/bootloader_esp32.o
*** [.pio/build/esp32-gateway/bootloader/signature_verification_key.bin.o] Source `.pio/build/esp32-gateway/bootloader/signature_verification_key.bin.S' not found, needed by target `.pio/build/esp32-gateway/bootloader/signature_verification_key.bin.o'.
================================================================================================================= [FAILED] Took 107.72 seconds =================================================================================================================
Environment Status Duration
esp32-gateway FAILED 00:01:47.724
============================================================================================================ 1 failed, 0 succeeded in 00:01:47.724 ============
File not where it needs to be:
$ find . -name \*.S
./.pio/build/esp32-gateway/x509_crt_bundle.S
./.pio/build/esp32-gateway/ca_cert.pem.S
./.pio/build/esp32-gateway/__pio_env/__dummy.S
./.pio/build/esp32-gateway/signature_verification_key.bin.S
Copy .S file to bootloader
directory:
$ cp ./.pio/build/esp32-gateway/signature_verification_key.bin.S ./.pio/build/esp32-gateway/bootloader
$ pio run
- tool-cmake 3.16.4
- tool-ninja 1.9.0
Linking .pio/build/esp32-gateway/bootloader.elf
Building .pio/build/esp32-gateway/bootloader.bin
esptool.py v3.1
Merged 1 ELF section
Linking .pio/build/esp32-gateway/firmware.elf
Retrieving maximum program size .pio/build/esp32-gateway/firmware.elf
Checking size .pio/build/esp32-gateway/firmware.elf
RAM: [= ] 5.6% (used 18492 bytes from 327680 bytes)
Flash: [===== ] 54.7% (used 573769 bytes from 1048576 bytes)
Building .pio/build/esp32-gateway/firmware.bin
esptool.py v3.1
Merged 2 ELF sections
================================================================================================================= [SUCCESS] Took 21.78 seconds =================================================================================================================
esp32-gateway SUCCESS 00:00:21.779
================================================================================================================= 1 succeeded in 00:00:21.779 =================================================================================================================
