Hi everyone!
I’m trying to use BluePill to communicate over built-in USB using Serial mode - and cannot get 2-way communication working…
Data from BluePill → desktop is transmitted, but nothing is received.
Tried another board - same result
If I use some sample program in Cube32IDE - both receiving and transmitting works, so that’s not a hardware issue.
here’s my environment:
[env:genericSTM32F103C8]
platform = ststm32
board = genericSTM32F103C8
lib_deps = thijse/CmdMessenger@^4.1.0
monitor_speed = 9600
upload_protocol = stlink
upload_flags = -c set CPUTAPID 0x2ba01477
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
-D USBD_USE_CDC
-D ENABLE_USB_SERIAL
-D USB_MANUFACTURER="UnknownMFG"
-D USB_PRODUCT="BluePill"
-D USBD_VID=0x0483
-D USBD_PID=0x5740
-D HAL_PCD_MODULE_ENABLED
;monitor_dtr = 0
debug_tool = stlink
and here’s the code itself:
const uint8_t kbStdLed = PC13; // Pin of Built-in LED
unsigned long lastTransmission;
void setup()
Serial.begin(9600);
while (!Serial);
pinMode(kbStdLed, OUTPUT);
void loop()
uint8_t incomingByte;
if ((millis() - lastTransmission) >= 2000)
Serial.println("Bbbnbnbas"); //<- this works
lastTransmission = millis();
if (Serial.available() > 0)
digitalWrite(kbStdLed, digitalRead(kbStdLed) ^ 1); //<- this doesn't work
incomingByte = Serial.available();
Serial.print("I received: "); //<- this doesn't work
Serial.println(incomingByte, DEC); //<- this doesn't work
Upon uploading the code, LED is off
After I connect via terminal program, it goes on - and stays on even if I send something
Serial.available() returns the number of bytes available to read .
Serial.read() reads an available byte, or returns -1 of none can be read.
Since in this case, you have already guarded executed with if(Serial.available() > 0), you can just
incomingByte = (char) Serial.read();
Serial.println(incomingByte);
You might also have to assert DTR = 1 in the platformio.ini, it it might ignore all input.
can you clarify please?
I tried like that:
-D DTR=1 in Build Flags - no changes
if I add to environment section - there’s a warning:
Warning! Ignore unknown configuration option dtr in section [env:genericSTM32F103C8]
Correct, I was trying to get at least some feedback (number of bytes sent in this case) - but no luck so far
First line (LED changing status) is to indicate if “IF” statement being fired - which apparently didn’t
jawa.bukowicz:
;monitor_dtr = 0
You already have the DTR I meant, just commented out. Comment it in, and try 0 as well as 1.
Then Serial.flush();
maxgerhardt:
didn’t help
tried a) after printing something
b) before checking if any incoming bytes available
no apparent changes…
when I check “DTR” in my terminal program - transmission starts (“Bbbnbnbas”),
when uncheck - stops
but incoming data is not read in both cases
I also noticed something strange: if I try to send something, this output “freezes” for ~2 seconds and then prints out 3 lines at once
This is working just fine-
platform = ststm32
-D USBCON
-D USBD_USE_CDC
'-D USB_MANUFACTURER="UnknownMFG"'
'-D USB_PRODUCT="BluePill"'
-D USBD_VID=0x0483
-D USBD_PID=0x5740
upload_protocol = cmsis-dap
monitor_dtr = 1
void setup()
Serial.begin(9600);
while (!Serial);
void loop()
char incomingByte;
Same in hterm
Thanks a lot for checking!
It looks like I’m out of luck with those clone boards then…
How did you manage to find original one?
I remember someone mentioning “wrong USB pullup resistor” during my searches - could this be the case here?
Can you make anything out of this picture?
R10 is 1.5K - looks correct
R9/R11 are 22 Ohm - close enough as well
jawa.bukowicz:
If you can get the board to be recognized via USB and send this data, then there is no problem with the USB pullup resistors.
Status update: I finally got USB communication working both ways.
Cheap clone board was the culprit… As soon as I got original one - the same code started working just fine
