I created a project with bluepill. The programme complies and uploads. The OLED connected also works but does not display the adc values, the on board led set to toggle with each iterations also do not work.
On debugging, the program enters the main() and then to HAL_Init(). from there it goes back to the main() , not moving to systemclock_config().
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
framework =stm32cube
board_build.mcu = stm32f103c8t6
board_build.f_cpu=72000000L
upload_protocol = stlink
build_type = debug
debug_tool = stlink ; Must be “custom” when using debug_server
; Tell OpenOCD to accept any CPU ID (0 = disable check)
board_debug.openocd_extra_args = -c “set CPUTAPID 0”
build_flags = -Wl,–undefined,_printf_float
debug_init_break = break main
extra_scripts = hex_script.py (this is only to convert .elf to .hex file).
when stepped into the HAL_init() , it goes upto HAL_Mspinit() –> __HAL_AFIO_REMAP_SWJ_NOJTAG()–end of Systeminit()–> startup_stm32f103f1x.s -.
/* Copy the data segment initializers from flash to SRAM */
ldr r0, =_sdata
ldr r1, =_edata
ldr r2, =_sidata
movs r3, #0
b LoopCopyDataInit
CopyDataInit:
ldr r4, [r2, r3]
str r4, [r0, r3]
adds r3, r3, #4
LoopCopyDataInit:
adds r4, r0, r3
cmp r4, r1
bcc CopyDataInit
it loops through the above codes continuesly and if continue is pressed, goes back to start of main(). What could be the reason for this ?
