I recently purchased the Pro plan to use PlatformIO on a variety of projects. As a sort of a noob to the mbed, Arduino and Raspberry Pi world I have a question regarding the Bluefruit Feather nRF52832. Is the Nordic nRF52-DK platform the one to use with this board? If not how can I get use this board with PlatformIO?
Thanks a lot for supporting us with PIO Plus! Could you try your board with Nordic nRF52-DK? It should work, including debugging.
Please confirm that it works, we will create a separate manifest for this board. Thanks!
Getting an Intellisense error with the #include along with this when I compile:
#include <bluefruit.h> ^ compilation terminated.
I remember I had to add this in Arduino Prefs,
Additional Boards Manager URL:
https://www.adafruit.com/package_adafruit_index.json
Also I’m running MacOS High Sierra 10.13.1 with VS Code 1.17.0
I went and downloaded the .tar from
https://adafruit.github.io/arduino-board-index/boards/adafruit-nrf52-0.5.0.tar.bz2
I then went through and added these to the #includePath in c_cpp_properties.json
“~/Documents/Arduino/libraries/adafruit-nrf52-0.5.0/libraries/Bluefruit52Lib”,
“~/Documents/Arduino/libraries/adafruit-nrf52-0.5.0/libraries/Bluefruit52Lib/src”,
“~/Documents/Arduino/libraries/adafruit-nrf52-0.5.0/libraries/Bluefruit52Lib/src/bluefruit.h”,
“~/.platformio/packages/framework-arduinonordicnrf5/cores/nRF5/SDK/components/softdevice/s132/headers”,
“~/.platformio/packages/framework-arduinonordicnrf5/cores/nRF5/SDK/components/softdevice/s110/headers”,
“~/.platformio/packages/framework-arduinonordicnrf5/cores/nRF5/SDK/components/softdevice/s120/headers”,
“~/Documents/Arduino/libraries/adafruit-nrf52-0.5.0/cores/nRF5”
I’m still getting the
Along with a lot of
class “BLEAdvertising” has no member “restartOnDisconnect”
This of course works with the Arduino IDE.
You should modify build flags using Redirecting...
Also, please copy whole library libraries/Bluefruit52Lib to project/lib folder.
I’m trying to perform these steps as well. The blinky example compiles, but I believe the firmware on the nRF is custom to work with Arduino and the USB bridge.
The log shows it’s uploading the program but I can see in the serial monitor that an old program I uploaded with Arduino is still running.
Are there any plans to add the Adafruit Feather nRF52 to the device list? I would greatly appreciate that so I can use the same platform as the development kit.
Or, which bootloader do I have to flash to make it work?
There is a feature request. Let’s wait when Adafruit send us a PR:
P.S: Try to post a feature request to their forum.
