Blue Pill + USB Serial
“Blue Pill” plate (STM32F103C8)
VSCode, Platformio (Home 2.0.0, Core 3.6.4)
Simply sketch:
Serial.println("+1");
delay(1000);
[env:bluepill_f103c8_128k]
platform = ststm32
board = bluepill_f103c8_128k
Сompiles, but Serial work not over USB, just two pins Tx, Rx (Expands to: Serial1). After plug-in USB in computer - “Unknown device”.
It happened after upgrade STM32 platform to 5.1.0 version. On v4.5.0 everything workd fine - appeared virtual COM-port over USB.
Unfortunately, even uninstall 5.1 and install 4.5 again - nothing compiling with numerous errors " duplicate ‘inline".
Can I fix this?
I,
i also have a bluepill board. When i connect usb to my win10 notebook i also have “Unknown device” error. I got working serial1, serial2, serial3 but can’t use USB.
Tried both latest stable and upstream platform with same result.
I even tried maple core (with no errors during compiling) but using it my test code don’t work at all.
I modified my bluepill with famous 1,5k resistor in place of 10k wrong one.
There is something wrong or missing?
[env:bluepill_f103c8]
; platform = ststm32          ; latest stable development platform
; platform = ststm32@~4.5.0   ; custom stable development platform
platform = https://github.com/platformio/platform-ststm32.git ; upstream development platform
; board_build.core = maple
upload_protocol = stlink
 -D ENABLE_HWSERIAL2
 -D ENABLE_HWSERIAL3
 -D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
 -D PIO_FRAMEWORK_ARDUINO_USB_HIGHSPEED
My test code
#define LED_BUILTIN PC13
void setup()
 pinMode(LED_BUILTIN, OUTPUT);
 Serial.begin(9600);
 Serial1.begin(9600);
 Serial2.begin(9600);
 Serial3.begin(9600);
void loop()
 digitalWrite(LED_BUILTIN, 1);
 Serial1.println("Serial LED OFF");
 Serial.println("Serial zero LED OFF");
 Serial2.println("Serial DUE LED OFF");
 Serial3.println("Serial TRE LED OFF");
 delay(1000);
 digitalWrite(LED_BUILTIN, 0);
 Serial1.println("Serial LED ON");
 Serial.println("Serial zero LED ON");
 Serial2.println("Serial DUE LED ON");
 Serial3.println("Serial TRE LED ON");
 delay(1000);
Some bluepill boards are having wrong resistors on the USB lines preventing it from properly working: BluePill and its annoyances | Details | Hackaday.io
Either maple should work out-of-the box (with board_build.core = maple) or use the build_flags (and only that) from Difficulty with getting USB serial [USB CDC] working - #18 by carlymx
Ok, thank you!
Work for me with this (even using latest stable development platform):
   -D USBCON
   -D USBD_VID=0x0483
   -D USBD_PID=0x5740
   -D USB_MANUFACTURER="Unknown"
   -D USB_PRODUCT="\"BLUEPILL_F103C8\""
   -D HAL_PCD_MODULE_ENABLED
With this configuration i have errors when compiling (says something missing)
	-D USBCON
	-D USBD_VID=0x0483
My original post is missing USBD_PID (it’s also very old and was correct, at the time of posting), I’ve corrected it. The post I linked to directly had everything.
