I’ve been struggling with it for a few days already and I still have no clue how to make it work with PlatformIO:
Using Arduino framework for bluepill_f103c8
board works fine, LED is blinking:
#define LED PC13
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
.ini
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
board_build.f_cpu = 72000000L
But I need to use stm32cube framework. However, after upload it doesn’t do anything.
#include "stm32f1xx_hal.h"
#define LED_PIN GPIO_PIN_13
#define LED_GPIO_PORT GPIOC
#define LED_GPIO_CLK_ENABLE() __HAL_RCC_GPIOA_CLK_ENABLE()
void LED_Init();
int main(void) {
HAL_Init();
LED_Init();
while (1) {
HAL_GPIO_TogglePin(LED_GPIO_PORT, LED_PIN);
HAL_Delay(1000);
void LED_Init() {
LED_GPIO_CLK_ENABLE();
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.Pin = LED_PIN;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
HAL_GPIO_Init(LED_GPIO_PORT, &GPIO_InitStruct);
void SysTick_Handler(void) { HAL_IncTick(); }
.ini
platform = ststm32
framework = stm32cube
In both cases I use STLink for upload.
