/* Blink Example
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
/* Can run 'make menuconfig' to choose the GPIO to blink,
or you can edit the following line and set a number here.
#define BLINK_GPIO CONFIG_BLINK_GPIO
void blink_task(void *pvParameter)
/* Configure the IOMUX register for pad BLINK_GPIO (some pads are
muxed to GPIO on reset already, but some default to other
functions and need to be switched to GPIO. Consult the
Technical Reference for a list of pads and their default
functions.)
gpio_pad_select_gpio(BLINK_GPIO);
/* Set the GPIO as a push/pull output */
gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
while(1) {
/* Blink off (output low) */
gpio_set_level(BLINK_GPIO, 0);
vTaskDelay(1000 / portTICK_PERIOD_MS);
/* Blink on (output high) */
gpio_set_level(BLINK_GPIO, 1);
void app_main()
xTaskCreate(&blink_task, "blink_task", configMINIMAL_STACK_SIZE, NULL, 5, NULL);
ini file
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
; http://docs.platformio.org/page/projectconf.html
[platformio]
home_dir = "/Users/Solid Snake/.platformio"
[env:esp-wrover-kit]
framework = espidf
board = esp-wrover-kit
; https://docs.espressif.com/projects/esp-idf/en/latest/get-started/get-started-wrover-kit.html#rgb-led
-D CONFIG_BLINK_GPIO=2
And it gave this
AVAILABLE: esp-prog, esptool, ftdi, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny
Looking for upload port...
Auto-detected: COM5
Uploading .pioenvs\esp-wrover-kit\firmware.bin
usage: esptool write_flash [-h] [--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
esptool write_flash: error: argument <address> <filename>: [Errno 2] No such file or directory: 'c:\\Users\\Solid'
*** [upload] Error 2
================================================================= [ERROR] Took 136.65 seconds =================================================================
Le processus du terminal s'est achevé avec le code de sortie 1
Le terminal sera réutilisé par les tâches, appuyez sur une touche pour le fermer.
I have a space in my PC name, there is a know this is a known issue with platformIO&ESPTOOL
But what canI do ? Look at the ini file I’ve put home_dir = "/Users/Solid Snake/.platformio"
but without success.
