Sir, this example uses Makefile
Can i compile with Platformio ? needs make
Some tips ?
Btw: i can compile on msys32
Exactly, that project is 4 years old and relies on the Makefile buildsystem. PlatformIO in its current version (and platform-espressif32 version) can only use the CMake build system. PlatformIO also needs a platformio.ini configuration. Please refer to the documentation on details, especially:
As an example, I’ve repackaged the above project to work PlatformIO in this repo: GitHub - maxgerhardt/pio-esp32-gatts-mqtt-gateway: A PlatformIO compilable version of https://github.com/pcbreflux/espressif/tree/master/esp32/app/ESP32_gatts_mqtt_gateway. Compiles fine and all Intellisense works.
This is a PlatformIO project and should be built with PlatformIO tools, not by using system-installed CMake commands. The build button is in the PlatformIO sidebar.
You might want to read the quickstart guide first before continuing.
Nice! Works!
Can you port this too ?
it will be util for all too!
