Hi
I’m using ESP32-C3, ESP-IDF, and esp32-c3-devkitm-1. I run a project example fast prove server example and added the “Store BLE Mesh configuration persistently” to store the joining network data in NVS flash to the project.
my problem is after joining the node to the network (my client is nRF Mesh mobile App), everything is correct but when I reset the ESP32 and want to connect to it again the ESP32 reset. and I can not join ESP32 with nRF Mesh Mobile App.
the reset error is:
E (17862) BT_OSI: osi_alarm_new alarm_cbs exhausted
assert failed: hash_map_set hash_map.c:129 (data != NULL)
Core 0 register dump:
MEPC : 0x403816be RA : 0x40389470 SP : 0x3fcb6450 GP : 0x3fc91000
TP : 0x3fc86b5c T0 : 0x37363534 T1 : 0x7271706f T2 : 0x33323130
S0/FP : 0x0000008e S1 : 0x00000001 A0 : 0x3fcb648c A1 : 0x3fc92a41
A2 : 0x00000001 A3 : 0x00000029 A4 : 0x00000001 A5 : 0x3fc9d000
A6 : 0x7a797877 A7 : 0x76757473 S2 : 0x00000009 S3 : 0x3fcb6599
S4 : 0x3fc92a40 S5 : 0x3fcb687c S6 : 0x00000000 S7 : 0x00000000
S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000
T3 : 0x6e6d6c6b T4 : 0x6a696867 T5 : 0x66656463 T6 : 0x62613938
MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x00000000
MHARTID : 0x00000000
Stack memory:
3fcb6450: 0x6e6d6c6b 0x6a696867 0x66656463 0x4038f1e2 0x3fc93298 0x3c0e4354 0x3fc93554 0x3c0e43d6
3fcb6470: 0x3fc932a8 0x3fcb6484 0x3fc932ac 0x3c0d4ecc 0x3fc92a40 0x00393231 0x3fca04d4 0x65737361
ELF file SHA256: 991d886fa7410010
Rebooting...
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0xe (SPI_FAST_FLASH_BOOT)
Saved PC:0x403812e0
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x16b4
load:0x403cc710,len:0x930
load:0x403ce710,len:0x2d28
entry 0x403cc710
Regards.
