BLE library for esp32 not working with Android app
Hi community…
I was trying to update the firmware of my esp32 mcu using this example
and From the android app I took th example here …
When I run the android app and try ti update the firmware the process starts but then the android app tells 100% download instead from the esp32 side from debug monitor it is saying imcomplete…
The same issue is reported here…
Does have idea how to fix it ?
Thanks a lot
Does it work when uploaded through the Arduino IDE?
Hi max… The ble library for esp32 works in platformio because using a python script i was able to update the firmware in the mcu…
The problem seems the interaction with the android app…
I didn’t try with arduino ide because as you know I use platformio with arduino framework set in the platformio.ini,
Can you do a test too?
Thanks a lot
