Blank PIO Home tab
My PIO Home tab is blank (empty of all content).
Environment
My PIO project resides on a Raspberry Pi 5 (RPi5) running the 64-bit version of Bookworm and is accessed remotely via Visual Studio Code (VSC) on MacOS 15.6.
Known
  • It used to work and then quit for an unknown reason at unknown time
  • Clicking the “Open” item under the “PIO Home” displays a blank tab
  • The PIO Home tab displays normally if I VNC from MacOS into the RPi5 and run VSC with PIO there (i.e. failure only occurs using VSC remote access)
  • The PIO Home tab displays normally on MacOS
  • Executing the “pio home” command in terminal on MacOS displays normally on MacOS
What I’ve Tried
  • Apt update/upgrade everything and reboot the RPi5
  • Apt reinstall python3 and pip on RPi5
  • Apt reinstall VSC (code) on RPi5
  • Uninstall/Install PIO extension locally on both MacOS and the RPi5
  • Profuse swearing :flushed:
  • On MacOS: Move VSC to trash, download and setup VSC with extensions. On RPi5, apt uninstall VSC, rm -fr .platformio, and apt reinstall python3-venv. PIO Home tab remains blank. :frowning:
  • On RPi5: Chromium browsing http://127.0.0.1:8008/ displays a PIO Home page
Any ideas for what else to try? :thinking:
So when you Install Shell Commands and, with VSCode and everything else closed, execute
pio home
on the commandline, what’s the output?
Accessing the RPi5 using VNC from MacOS, the “pio home” command on the RPi5 bash command-line brings up chromium and displays the PIO Home page with my recent projects at the bottom of the window.
Executing Visual Studio Code locally on the RPi5 and opening a PlatformIO project there displays the PIO Home page correctly.
The failure only occurs when I access the RPi5 PlatformIO project remotely from Visual Studio on MacOS.
The RPi5 PlatformIO project builds successfully when accessed remotely from Visual Studio on MacOS.
Curiouser and curiouser… :thinking:
And how do you do that? What buttons do you use or what commands do you use? As I understand PIO Remote, it’s only used for pushing projects to a remote host and compiling, uploading or monitoring them there. I’ve never seen the PIO Home page being accessed remotely via PIO Remote.
Oh, you are so right (I “knew” this was going to end in some form of “my bad”;). Remoting has worked so transparently that I neglected to consider the PIO Home tab may only be functional on local, not remote, projects. :flushed:
