I’m just starting some development with a Black Pill STM32F411CE V3.1. Not very familiar with STM CPUs. Using an STLINK/V2 (genuine ST one) for all comms, not using the USB port at all.
Was getting on fine with some test code toggling PA5 and PC13 (the LED). But, then made a silly mistake. On making a change, set PA13 as one of the output ports, not PC13. PA13 - I notice - is one the the SWD port pins.
The result is now, I cannot upload any code at all, it fails on trying to upload. It says:
Uploading .pio\build\blackpill_f411ce\firmware.elf
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
Error: init mode failed (unable to connect to the target)
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
I assume this is because the code currently in flash has configured PA13 as an output and the STLINK cannot talk to it.
Cannot find a way out of this. Can anyone help?
My platformio.ini is:
[env:blackpill_f411ce]
platform = ststm32
board = blackpill_f411ce
framework = stm32cube
upload_protocol = stlink
debug_tool = stlink
UPDATE:
Booting with boot0 held down seemed to do it. Don’t know if that is the ‘correct’ approach.
