Well, this was (and still is) seriously weird. I’m suspecting a bug in the version of avr-g++
installed by the latest updates to PlatformIo – but that’s not a PlatformIO problem as such.
Has anyone seen anything as weird as the following?
TL;DR
One line of code in an ISR:
m += MILLIS_INC;
didn’t get compiled into the binary. After changing the line to something equivalent, but hard coded:
m++;
it did work. Changing back to the original now works!
Gory Details
Version of avr-g++:
norman@Hubble $ ./avr-g++ --version
avr-g++ (AVR_8_bit_GNU_Toolchain_3.6.2_1759) 5.4.0
Version of PlatformIO:
norman@Hubble $ pio system info
PlatformIO Core 5.0.4
Python 3.6.9-final.0
System Type linux_x86_64
Platform Linux-5.4.0-58-generic-x86_64-with-glibc2.25
File System Encoding utf-8
Locale Encoding UTF-8
PlatformIO Core Directory /home/norman/.platformio
PlatformIO Core Executable /home/norman/.local/bin/platformio
Python Executable /usr/bin/python3
Global Libraries 0
Development Platforms 4
Tools & Toolchains 19
Background
I’m writing a small library to be used when I’m not using the Arduino framework, and writing plain AVR C++. I’ve got a need for the millis()
(and micros()
) function, so I’ve come up with a class (AVR_millis
) which handles the Timer/counter 0 Overflow Interrupt in a very similar manner to how the Arduino does it. The difference is that mine is encapsulated in a class.
The interrupt handling code is as follows:
void AVR_millis::interrupt() {
// Grab the current values.
uint32_t m = timer0_millis;
uint8_t f = timer0_fract;
// Increment millis counter by the number of
// milliseconds per overflow period.
m += MILLIS_INC;
// Accumulate the fractions of a millisecond
// per overflow period.
f += FRACT_INC;
// Do we have a "leap" milliseconds yet? If so,
// add it in and adjust the fraction.
if (f >= FRACT_MAX) {
f -= FRACT_MAX;
m += 1;
// Copy the new values back to the class variables.
timer0_fract = f;
timer0_millis = m;
// How many times have we overflowed since "time began"?
timer0_overflow_count++;
So, I wrote a small test to blink an LED (how original) using the new class and nothing happened. Yes, I did enable global interrupts – which is unusual for me I admit.
Grabbing millis()
, delaying 20 milliseconds and grabbing millis()
again should have resulted in a difference of around 20, they were the same value. WTH?
Maybe I’ve not set the rehisters up correctly to enable the interrupt. I added another LED and turned it on in the ISR. I now know that the ISR is definitely executing thanks to the LED. So why was nothing else working properly in the ISR?
I ran avr-objdump -S
to get a dissassembly, the ISR generated the following code. Comments are mine. Can you see what’s missing?
Disassembly of section .text:
00000000 <__vectors>:
RESET:
0: 0c 94 35 00 jmp 0x6a ; 0x6a <__ctors_end>
TIMER0_OVF
40: 0c 94 54 00 jmp 0xa8 ; 0xa8 <__vector_16>
000000a8 <__vector_16>:
ISR(TIMER0_OVF_vect)
ISR preamble, saving lots of registers.
a8: 1f 92 push r1
m = timer0_millis
c2: 40 91 04 01 lds r20, 0x0104 ; 0x800104 <_edata+0x4>
c6: 50 91 05 01 lds r21, 0x0105 ; 0x800105 <_edata+0x5>
ca: 60 91 06 01 lds r22, 0x0106 ; 0x800106 <_edata+0x6>
ce: 70 91 07 01 lds r23, 0x0107 ; 0x800107 <_edata+0x7>
f = timer0_fract
d2: 80 91 08 01 lds r24, 0x0108 ; 0x800108 <_edata+0x8>
if (f >= FRACT_MAX)
d6: 8d 37 cpi r24, 0x7D ; 125
d8: 28 f0 brcs .+10 ; 0xe4 <__vector_16+0x3c>
f -= FRACT_MAX
da: 8d 57 subi r24, 0x7D ; 125 FRACT_MAX
m++ (// Adding 1 by subtracting -1 weird!)
dc: 4f 5f subi r20, 0xFF ; 255
de: 5f 4f sbci r21, 0xFF ; 255
e0: 6f 4f sbci r22, 0xFF ; 255
e2: 7f 4f sbci r23, 0xFF ; 255
timer0_fract = f
e4: 80 93 08 01 sts 0x0108, r24 ; 0x800108 <_edata+0x8>
timer0_millis = m
e8: 40 93 04 01 sts 0x0104, r20 ; 0x800104 <_edata+0x4>
ec: 50 93 05 01 sts 0x0105, r21 ; 0x800105 <_edata+0x5>
f0: 60 93 06 01 sts 0x0106, r22 ; 0x800106 <_edata+0x6>
f4: 70 93 07 01 sts 0x0107, r23 ; 0x800107 <_edata+0x7>
f8: 80 91 00 01 lds r24, 0x0100 ; 0x800100 <_edata>
fc: 90 91 01 01 lds r25, 0x0101 ; 0x800101 <_edata+0x1>
100: a0 91 02 01 lds r26, 0x0102 ; 0x800102 <_edata+0x2>
104: b0 91 03 01 lds r27, 0x0103 ; 0x800103 <_edata+0x3>
108: 01 96 adiw r24, 0x01 ; 1
10a: a1 1d adc r26, r1
10c: b1 1d adc r27, r1
10e: 80 93 00 01 sts 0x0100, r24 ; 0x800100 <_edata>
112: 90 93 01 01 sts 0x0101, r25 ; 0x800101 <_edata+0x1>
116: a0 93 02 01 sts 0x0102, r26 ; 0x800102 <_edata+0x2>
11a: b0 93 03 01 sts 0x0103, r27 ; 0x800103 <_edata+0x3>
ISR postamble, restoring lots of registers.
134: 1f 90 pop r1
136: 18 95 reti
That’s correct, this line of source code is not compiled into the ISR:
m += MILLIS_INC;
I know, because I worked it out, that MILLIS_INC
is the value 1. Much random messing about with volatile
and register
made absolutely no difference. That one line remained missing from the binary.
Given that the increment is 1, I changed the above line to:
m++;
A quick rebuild and upload, and it worked – yippee!
So, everything is working fine, however, I need to un-hardcode the increment because the increment is required to be calculated against F_CPU
. Let’s try again.
I changed it back and recompiled. After an upload I was expecting to see a blank LED, but no, it was indeed flashing away happily. Huh?
So, in summary:
- Compiling with
m += MILLIS_INC
didn’t work; - Compiling with
m++
did work; - Compiling again with
m += MILLIS_INC
now works!
This is worrying as it has been a long time since I have seen this type of behaviour. That was COBOL and some code I wrote worked fine if I added a DISPLAY
statement, and failed with the statement removed – it had to be left in as even the compiler writers couldn’t find a problem. (ICL mainframe.)
The other worry is that my code almost never works first time, I’m now in a situation of wondering if the problem is my code, or another gem like this one. Still, I’m getting lots of experience looking through what the compiler outputs for my source!
So, that’s my tale of woe and is how I spent yesterday afternoon and early evening, debugging this one.
May you never suffer from anything like this, ever!
Cheers,
Norm.
