Exactly, the code was meant to be an .ino file and not a .cpp file; The Arduino IDE does pre-processing on the file, namely, scanning the file for every function implementation and declaring it at the top of the file.
This is invalid C++ code (but valid .ino because of the preprocessing):
doStuff();
void doStuff() {
Serial.println("Doing stuff..");
because at the time of usage, doStuff() is not previously declared, thus unknown to the compiler. This is fixed by adding the function declaration void doStuff(); over the setup() function.
You can:
- rename your
main.cppfile tomain.inoto make PIO also do the same preprocessing - or fix the source by making it actually valid C++; see the documentation / FAQ
