Hi!
I’m very new to this, so a very very basic question: I am trying to get the Blink scetch to work on an Arduino Nano.
I am following the Dronebot video in detail: Getting Started with PlatformIO - YouTube
I can compile and run the code with the Arduion IDE but when copying the code into Platform IO, it compiles, seems to upload, but no blink.
In Arduino IDE I set the board to ATmega328P (old bootloader) and in Platform IO to atmega328 (that comes up when I type arduino nano in the board chooser).
Any ideas what is wrong here? What am I missing?
Magnus
Please show full platformio.ini, code and output of the ‘Upload’ project task.
You also sure you that you have switched to the project you want if you’ve created multiple ones? (project environment switcher).
Hi!
Here’s the platform.ini code:
; ... (deleted to be able to reply)
[env:nanoatmega328]
board = nanoatmega328
Here’s the output from “Upload”:
> Executing task in folder blink: platformio run --target upload <
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (3.3.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
- framework-arduino-avr 5.1.0
LDF: Library Dependency Finder -> ... (deleted to be able to reply)
Found 5 compatible libraries
Checking size .pio/build/nanoatmega328/firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 1.4% (used 444 bytes from 30720 bytes)
AVAILABLE: arduino
Looking for upload port...
Warning! Please install `99-platformio-udev.rules`.
More details: ... (deleted to be able to reply)
Auto-detected: /dev/ttyUSB0
Uploading .pio/build/nanoatmega328/firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pio/build/nanoatmega328/firmware.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.15s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against .pio/build/nanoatmega328/firmware.hex:
avrdude: load data flash data from input file .pio/build/nanoatmega328/firmware.hex:
avrdude: input file .pio/build/nanoatmega328/firmware.hex contains 444 bytes
Reading | ################################################## | 100% 0.11s
avrdude: verifying ...
avrdude: 444 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
As for switching: as I am totally new, I am not really sure what you mean. I have the code I want to upload in the window, and below that click the compile and upload icons. Did I miss something there?
Magnus
Ah… now it works. I found the Project Environment Switcher, however, upon chaning project environment, clikcing the “run” icon only brought up a chooser. So I closed the program and restarted, and now it works!
Thanks!
Magnus
And what is the code?
And the file the code is in the src/main.cpp file of the project, yes? It can’t just be in a new unsaved file.
Also, you only need project environment switching if you have multiple projects open, aka. multiple workspace folders.
Here you can see in the upper left corner that I have a billion projects in my workspace, and to work on a specific project, I need to use the project environment switcher in the blue taskbar to select it (generic-lora-node). And of course the code I want to upload must be in a file in src/ of that project.
Thanks! Yes, src/main.cpp
It’s slowly getting clearer! Feels a bit steep learning curve, so thanks a lot for your help!!
Magnus
