Hi everybody,
so far, I only cloned projects that I then built via platformio; now I am trying to finally learn to work with my arduinos and write my own code.
I am trying to create functions, googled some code, and modified it to this
Serial.begin(9600);
meins();
//Serial.println("| Program Menu |");
void meins()
Serial.println("ok");
delay(500);
Serial.println("yo!");
When I upload this via arduino ide to my Arduino Nano Atmega328, it will work: the monitor will display “ok”, wait 500ms, then display “yo!”, then stop doing anything.
So then I created a platformio project for this.
platformio.ini
[env:nanoatmega328]
board = nanoatmega328
monitor_speed = 9600
upload_port = /dev/ttyUSB0
src/main.cpp
Serial.begin(9600);
meins();
void meins()
delay(500);
When I try upload and monitor I receive the output from below. Why is that? The code seems to be correct, the hardware information ought to be correct… what am I doing wrong?
Again, this very code will run via arduino ide; I assumed that it’d work in pio as well, as long as I #include <Arduino.h>…
Thank you for your feedback
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR 2.0.0 > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
- framework-arduino-avr 5.0.0
- tool-avrdude 1.60300.190424 (6.3.0)
Found 5 compatible libraries
Compiling .pio/build/nanoatmega328/src/main.cpp.o
src/main.cpp: In function 'void setup()':
src/main.cpp:5:9: error: 'meins' was not declared in this scope
meins();
Archiving .pio/build/nanoatmega328/libFrameworkArduino.a
*** [.pio/build/nanoatmega328/src/main.cpp.o] Error 1
Indexing .pio/build/nanoatmega328/libFrameworkArduino.a
========================================================================================================== [FAILED] Took 0.37 seconds ==========================================================================================================
