My head is exploding with the step from arduino to c++ in PLatformio but Im enjoying it at the same time
I have this fucntion:
void loadSong(byte songno) {
byte songx[]={};
if (songno==2) songx[]=song2[];
if (songno==3) songx[]=song3[];
if (songno==4) songx[]=song4[];
if (songno==5) songx[]=song5[];
for (byte j = 0; j <= 254; j++) {
opl2.setRegister(j, songx[j]);
Obviously, what I want is to receive an int or byte and depending of the number of the byte, pass a different array to that function, but for the nails of Christ that I can´t find the appropiate syntax.
When you assign variables of any type (integral type, pointer or array), you just assign var1 = var2; and never put [] after the variable (unless of course you want to dereference it, like var1 = var2[some_index]; or you need a cast first)
I think what you meant to do is have a byte* which points to the 255-byte long song, but depending on the song number the songx pointer points to a different song. So something like
The (byte*) cast is for the case that song2 is defined as a byte array of known size, and GCC will complain when you assign this array to a simple pointer variable. But it’s perfectly valid here. You can also write &song2[0] to get a byte* to the start of the song
