Hey all, I’ve got a newb question that I just can’t seem to find an answer for.
I use two boards for my projects, an ESP8266 and an ESP32; and use both USB and OTA for updating.
I’d like to be able to quickly change the build configuration between the 4 possible permutations of the build.
My platformio.ini is below, which doesn’t work as expected. I’d like to be able to select the board and the USB/OTA by changing the default_envs line rather than having to constantly change the board configuration depending on what I’m building.
Thanks!
[platformio]
monitor_speed=115200
default_envs = nodemcuv2,usb
[env:usb]
upload_protocol = esptool
[env:ota]
upload_protocol = espota
upload_port = 192.168.1.100
[env:devkit]
board = esp32doit-devkit-v1
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
The question you should be asking is “How does env:usb
and env:ota
relate to env:devkit
and env:nodemcuv2
?” i.e. How does PlatformIO know they are connected?
This isn’t the prettiest, but this is the best I can come up with atm to actually do what you want…
First things first… monitor_speed isn’t a valid option for [platform]
… you want that in [env]
if it’s a global speed option… and I shoved framework
there also since that’s the same for all the boards. Next up, some base level environments (e.g espressif32_base
, usb
, etc) which can then be used with extends
for some creative building up of the actual board environments and save duplication that way. Which then gives:
[platformio]
default_envs = nodemcuv2-usb
[env]
[env:espressif32_base]
[env:espressif8266_base]
[env:usb]
[env:ota]
[env:devkit-ota]
extends = env:espressif32_base, env:ota
[env:devkit-usb]
extends = env:espressif32_base, env:usb
[env:nodemcuv2-ota]
board = nodemcuv2
extends = env:espressif8266_base, env:ota
[env:nodemcuv2-usb]
board = nodemcuv2
extends = env:espressif8266_base, env:usb
If that makes sense, great, otherwise don’t hesitate to ask away! ![:wink: :wink:](https://community.platformio.org/images/emoji/twitter/wink.png?v=12)
