I would like to use the platformio with a bare metal ATSAMD51 processor. That is not using Arduino or mbed, etc. I read through the documentation but do not understand how to do this. Basically I just want to select the compiler and debugger and then add my code.
So I do not need a framework to compile and upload code? How does platformIO know which processor, and compiler? How do I set the linker options, and compiler options?
We work on ability to start a project using DEVICE workflow instead of dev kits. A temporary solution is to use the most close board and do not define framework option.
OK I have tried to figure out how to create custom board/platform, and it is very confusing.
For example I looked at the atmelsam platform and it is a confusing as there is a platform.json and platform.py which seems to duplicate information, why is the data duplicated? Also there is the builder for frameworks, ie arduino.py, simba.py, _bare.py, etc. It appears that these scripts define the compiler flags (CCFLAGS) thus it is a bit confusing how one would build a project for debugging (-O0) when in the build script it is hard coded for -Os. Specifically I usually compile code with -O0 when I am debugging and then compile with -Os for release builds. Sometimes I even have to compile some files -Os and then compile specific files I am debugging with -O0. Is this possible in PlaftormIO?
I can see the value in PlatformIO downloading the packages (tool chain, debugger, etc) that is needed for a board, however it appears to remove all flexibility and configuration for your project. So I am wondering if PlatformIO is intentionally this confusing, or am I missing some key design philosophy which is limiting my mental model of how PlatformIO is intended to work?
That is why would I choose to use PlatformIO over cmake or makefile?
See Redirecting.... You can modify the CCFLAGS/CFLAGS for env and projenv independently, so it should be possible to mix -Os code with -O0 code. Use pio run -v to get verbose compile commands to verify this.
I could not figure it out in platformio and just went back to using eclipse. One day maybe when platformio has better documentation I will look at it again. Again it might be great to replace Arduino IDE, but it does not do what I need for ‘real’ embedded development.
I did get firmware building with good old fashion makefile which worked great but then the Cortex_debug plugin is not there yet for using vscode, in the two the three seconds of use I several bugs.
Eclipse IDE appears to be much more user friendly and stable. Sure the editor is not as ‘fast’ but I would rather have good slow tools than fast bad ones.
