Banned IP Address?
I’ve a lot of problem accessing to platformio.org as my IP address was banned. The same happen when I compile sorce code the system stuck in
waiting for connection.
The only way to restore the connection for a while (less than 1 hour) is to reset the PPPoE on internet router forcing a change in IP Address.
Could anyone help me?
Thanks in advance
Stefano
Huh? I’ve never seen that happen. Or even knew it was possible.
You’re not banned from the forum is the only thing I can see.
Do you mean your ISP has banned you or the PlatformIO servers have somehow banned you? PlatformIO should still work in offline mode though…
@ivankravets I think that’s a topic for you
Hey! Finally, we have found you! :rocket:
Over 1000 requests per 1 sec from your machine to our servers. You change IPs very often. We thought this is DDoS attack.
I’ll contact you personally to investigate the issue.
P.S: Our apologies, we thought this a bot/attack.
would love to know what caused this, I may have a similar issue now.
