Hello, I’ve just started using PIO and ran into some problems. Some details
PIO version 4.3.3 / 3.2.2
Platform: timsp430
Framework: Arduino
Problem 1: compile flags. Solved this by adding (debug_build_flags = “-O0”, “-g3”, “-ggdb” “-gdwarf-2”) in platformio.ini. It was complaining about -Og. I can download the program fine.
Problem 2: While trying to debug, I get the following error.
MSP430_OpenDevice
MSP430_GetFoundDevice
Device: F20x2_G2x2x_G2x3x (id = 0x0035)
2 breakpoints available
MSP430_EEM_Init
Chip ID data:
ver_id: 01f2
ver_sub_id: 0000
revision: 30
fab: 40
self: 0000
config: 02
Bound to port 2000. Now waiting for connection…
Remote register badly formatted: T0500:00f80000;01:74020000;02:00000000;03:00000000;04:ffce0000;05:085a0000;06:effe0000;07:3ff60000;08:6f030000;09:00000000;0a:a8440000;0b:b9860000;0c:a35c0000;0d:43000000;0e:40050000;0f:00000000;
here: 0000;01:74020000;02:00000000;03:00000000;04:ffce0000;05:085a0000;06:effe0000;07:3ff60000;08:6f030000;09:00000000;0a:a8440000;0b:b9860000;0c:a35c0000;0d:43000000;0e:40050000;0f:00000000;
This is where I have no idea what to do next. Any suggestions?
[env:lpmsp430g2553]
platform = timsp430
board = lpmsp430g2553
debug_build_flags = -O0 -g2 -ggdb2
debug_tool = custom
debug_port = :39102
debug_server =
/Users/gregory/.platformio/packages/tool-mspdebug/mspdebug
rf2500
"gdb 39102"
I’m running on macOS Catalina with a TI Launchpad MSP-EXP430G2 w/ MSP430G2553 and a modified kernel extension. The kernel extension works because when I run mspdebug outside of platformio, it successfully communicates with the launchpad (break, step, and run make the factory blink program stop and start as expected) although I have yet to download a program using either. I am not using arduino or energia (I intend to use native), so my main.cpp program is just:
int main() {}
I get a similar error:
Processing lpmsp430g2553 (platform: timsp430; board: lpmsp430g2553)
CONFIGURATION: https://docs.platformio.org/page/boards/timsp430/lpmsp430g2553.html
PLATFORM: TI MSP430 2.2.0 > TI LaunchPad MSP-EXP430G2553LP
HARDWARE: MSP430G2553 16MHz, 512B RAM, 16KB Flash
DEBUG: Current (custom) On-board (mspdebug)
- toolchain-timsp430 1.40603.190926 (4.6.3)
Found 0 compatible libraries
Building in debug mode
Checking size .pio/build/lpmsp430g2553/firmware.elf
RAM: [ ] 0.4% (used 2 bytes from 512 bytes)
Flash: [ ] 0.7% (used 112 bytes from 16384 bytes)
========================= [SUCCESS] Took 1.28 seconds =========================
MSPDebug version 0.23 - debugging tool for MSP430 MCUs
Copyright (C) 2009-2015 Daniel Beer <dlbeer@gmail.com>
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Chip info database from MSP430.dll v3.3.1.4 Copyright (C) 2013 TI, Inc.
Trying to open interface 1 on 008
Initializing FET...
FET protocol version is 30394216
Set Vcc: 3000 mV
Configured for Spy-Bi-Wire
Using Olimex identification procedure
undefinedfet: FET returned error code 4 (Could not find device or device not supported)
fet: command C_IDENT1 failed
Device ID: 0x2553
Code start address: 0xc000
Code size : 16384 byte = 16 kb
RAM start address: 0x200
RAM end address: 0x3ff
RAM size : 512 byte = 0 kb
Device: MSP430G2xx3
Number of breakpoints: 2
fet: FET returned NAK
warning: device does not support power profiling
Chip ID data: 25 53
Bound to port 39102. Now waiting for connection...
Reading symbols from /Users/gregory/Documents/PlatformIO/Projects/Launchpad Test/.pio/build/lpmsp430g2553/firmware.elf...
done.
PlatformIO: debug_tool = custom
Client connected from 127.0.0.1:54070
Clearing all breakpoints...
Connection closed
Remote register badly formatted: T0500:c2fc0000;01:7a020000;02:00000000;03:00000000;04:b74d0000;05:07160000;06:4f850000;07:cfe90000;08:97e00000;09:a2d60000;0a:fb840000;0b:7a8e0000;0c:00000000;0d:90fd0000;0e:00000000;0f:ffff0000;
here: 0000;01:7a020000;02:00000000;03:00000000;04:b74d0000;05:07160000;06:4f850000;07:cfe90000;08:97e00000;09:a2d60000;0a:fb840000;0b:7a8e0000;0c:00000000;0d:90fd0000;0e:00000000;0f:ffff0000;
I get the same error using mspdebug v0.24 and v0.25 (latest) refuses to connect to the launchpad at all.
I don’t want to hijack the thread, but this seemed the right place to put this since it’s the most recent thread on the topic.
—EDIT—
One further note I just discovered, everything works fine when just uploading using the same configuration except adding upload_protocol = rf2500 to the platformio.ini (meaning a program downloaded and ran successfully). It seems to be a problem with just debug mode.
Interesting, so a new version of mspdebug should fix the problem for all used GDB versions? The issue 78 is still open though, was the fix ever merged?
