Hi All,
I am working on esp32-idf. I found Azure IoT Arduino Library on PlatformIO. So, can we use same library for IDF framework or is there any other support are available.
Thanks,
Harsh
Hi All,
Thanks,
Harsh
Which ESP32-IDF version are you using for the project?
We are using latest version which is 4.0 release.
You’re talking about this library? PlatformIO Registry. This is an Arduino-ESP32 library.
Per Support for ESP IDF v4 - #5 by ivankravets this isn’t yet available, with an estimate of “hopefully released in this month.” But since the library is written against the Arduino-ESP32 core and not ESP-IDF directly, it’s a special case. It’s possible to build ESP-IDF with additionally the Arduino core built in, so that Arduino libraries can run, for compatibility. See e.g. espidf-arduino-blink example. Since the latest supported version of ESP-IDF is v3.3 currently, you should be able to get ESP-IDF v3.3 + Arduino Core + this library working. After v4 is released for PIO, this is then upgraded respectively.
