hello, as a newbe i need help in finding solution to this error when i try to upload simple avr code that already compliled success in platformio
but upon uploading i encounter this error :
Looking for upload port...
Error: Please specify `upload_port` for environment or use global `--upload-port` option.
For some development platforms it can be a USB flash drive (i.e. /media/<user>/<device name>)
*** [upload] Explicit exit, status 1 "
and this
" Configuring upload protocol...
AVAILABLE: custom
CURRENT: upload_protocol = custom
Uploading .pio\build\program_via_AVRISP_mkII\firmware.hex
avrdude: can't open config file " /tool-avrdude/avrdude.conf": No such file or directory
avrdude: error reading system wide configuration file " /tool-avrdude/avrdude.conf"
*** [upload] Error 1
========================================== [FAILED] Took 2.84 seconds ==========================================
Environment Status Duration
ATmega16 FAILED 00:00:05.967
program_via_AVRISP_mkII FAILED 00:00:02.835
===================================== 2 failed, 0 succeeded in 00:00:08.803 =====================================
here is my .ini file
[env:ATmega16]
board = ATmega16
[env:program_via_AVRISP_mkII]
board = ATmega16
upload_port = usb
upload_flags =
-C $PROJECT_PACKAGE_DIR/tool-avrdude/avrdude.conf
-p $BOARD_MCU
-p $UPLOAD_PORT
-c avrispmkII
-c stk500v2
i check the avrdude.conf in the directory (c:users/…tool-avrdude/avrdude.conf)and it is there but why platformio say no such file ?
Check your Env Variable PROJECT-PACKAGE-DIR.
May be it is empty. see line with can’t open… " /tool-avrdude…"
In .ini file you specify -C with this variable. try with the full path of this conf file.
You have a simple typo, this variable is called
# Setup project optional directories
config = env.GetProjectConfig()
app.set_session_var("custom_project_conf", config.path)
env.Replace(
PROJECT_DIR=get_project_dir(),
PROJECT_CORE_DIR=config.get("platformio", "core_dir"),
PROJECT_PACKAGES_DIR=config.get("platformio", "packages_dir"),
PROJECT_WORKSPACE_DIR=config.get("platformio", "workspace_dir"),
PROJECT_LIBDEPS_DIR=config.get("platformio", "libdeps_dir"),
PROJECT_INCLUDE_DIR=config.get("platformio", "include_dir"),
PROJECT_SRC_DIR=config.get("platformio", "src_dir"),
PROJECTSRC_DIR="$PROJECT_SRC_DIR", # legacy for dev/platform
PROJECT_TEST_DIR=config.get("platformio", "test_dir"),
PROJECT_DATA_DIR=config.get("platformio", "data_dir"),
PROJECTDATA_DIR="$PROJECT_DATA_DIR", # legacy for dev/platform
PROJECT_BUILD_DIR=config.get("platformio", "build_dir"),
BUILD_TYPE=env.GetBuildType(),
hence the variable you access is empty, leading to a /tool-avrdude/avrdude.conf
path.
hi max,
i think the avr_dude problem solved by providing full path, thanks.
but still get the “upload port error” here is the complete terminal
Processing ATmega16 (platform: atmelavr; board: ATmega16)
------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega16.html
PLATFORM: Atmel AVR (4.2.0) > ATmega16
HARDWARE: ATMEGA16 16MHz, 1KB RAM, 16KB Flash
DEBUG: Current (simavr) External (simavr)
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 0 compatible libraries
Checking size .pio\build\ATmega16\firmware.elf
RAM: [ ] 0.0% (used 0 bytes from 1024 bytes)
Flash: [ ] 0.8% (used 138 bytes from 16384 bytes)
AVAILABLE: arduino
=========================================== [FAILED] Took 5.01 seconds ===========================================
ATmega16 FAILED 00:00:05.008
===================================== 1 failed, 0 succeeded in 00:00:05.008 =====================================
* The terminal process "C:\Users\awadjafar\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload', '--environment', 'ATmega16'" terminated with exit code: 1.
my platformio.ini already specify p
[env:ATmega16]
board = ATmega16
board = ATmega16
upload_port = usb
upload_flags =
-C \Users\awadjafar\.platformio\packages\tool-avrdude\avrdude.conf
-p $BOARD_MCU
-p $UPLOAD_PORT
-c avrispmkII
-c stk500v2
when i check “windows device manager” the avrispmk2 connected and works.
why i get upload_port error above ?
thanks
How can that be two protocols at the same time? That doesn’t make sense. It’s either an avrispmkii or a stk500v2.
As you can see when you set board = ATmega16
it pulls the upload settings from
"upload": {
"maximum_ram_size": 1024,
"maximum_size": 16384,
"protocol": "arduino",
"require_upload_port": true,
"speed": 115200
and it requires an upload port in its default configuration. Now if you have a USB programmer that does not show up as a COM port but only as some USB HID device or whatever, then it doesn’t make sense to wait for a COM port. So just add
board_upload.require_upload_port = no
to the platformio.ini
to override that.
hi max,
thanks for the help, as a newbie here, i am confuse how should my platformio.ini looks like because don’t know where to put the command “board_upload.require_upload_port = no” , i have tried different places but still get error
board = ATmega16
upload_port = usb
upload_flags =
-p $BOARD_MCU
-p $UPLOAD_PORT
-c avrispmkII
i also try to remove “upload_port = usb” and “-p $upload_port” but still get the error.
thanks
fsyammach:
The same error? Can you post it in full?
hi max, here is my .ini file
[env:ATmega16]
board = ATmega16
board = ATmega16
upload_port = usb
upload_flags =
-C
-p
$BOARD_MCU
-p
$UPLOAD_PORT
-c
avrispmkII
and here is the error that i get
---------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
RAM: [ ] 0.2% (used 2 bytes from 1024 bytes)
Flash: [= ] 10.6% (used 1730 bytes from 16384 bytes)
AVAILABLE: arduino
============================================ [FAILED] Took 4.74 seconds ============================================
Processing program_via_AVRISP_mkII (platform: atmelavr; board: ATmega16)
Checking size .pio\build\program_via_AVRISP_mkII\firmware.elf
AVAILABLE: custom
avrdude: AVR Part "usb" not found.
Valid parts are:
uc3a0512 = AT32UC3A0512
c128 = AT90CAN128
c32 = AT90CAN32
c64 = AT90CAN64
pwm2 = AT90PWM2
pwm216 = AT90PWM216
pwm2b = AT90PWM2B
pwm3 = AT90PWM3
pwm316 = AT90PWM316
pwm3b = AT90PWM3B
1200 = AT90S1200
2313 = AT90S2313
2333 = AT90S2333
2343 = AT90S2343
4414 = AT90S4414
4433 = AT90S4433
4434 = AT90S4434
8515 = AT90S8515
8535 = AT90S8535
usb1286 = AT90USB1286
usb1287 = AT90USB1287
usb162 = AT90USB162
usb646 = AT90USB646
usb647 = AT90USB647
usb82 = AT90USB82
m103 = ATmega103
m128 = ATmega128
m1280 = ATmega1280
m1281 = ATmega1281
m1284 = ATmega1284
m1284p = ATmega1284P
m1284rfr2 = ATmega1284RFR2
m128rfa1 = ATmega128RFA1
m128rfr2 = ATmega128RFR2
m16 = ATmega16
m161 = ATmega161
m162 = ATmega162
m163 = ATmega163
m164a = ATmega164A
m164p = ATmega164P
m164pa = ATmega164PA
m168 = ATmega168
m168p = ATmega168P
m168pb = ATmega168PB
m169 = ATmega169
m16u2 = ATmega16U2
m2560 = ATmega2560
m2561 = ATmega2561
m2564rfr2 = ATmega2564RFR2
m256rfr2 = ATmega256RFR2
m32 = ATmega32
m324a = ATmega324A
m324p = ATmega324P
m324pa = ATmega324PA
m324pb = ATmega324PB
m325 = ATmega325
m3250 = ATmega3250
m328 = ATmega328
m328p = ATmega328P
m328pb = ATmega328PB
m329 = ATmega329
m3290 = ATmega3290
m3290p = ATmega3290P
m329p = ATmega329P
m32m1 = ATmega32M1
m32u2 = ATmega32U2
m32u4 = ATmega32U4
m406 = ATMEGA406
m48 = ATmega48
m48p = ATmega48P
m48pb = ATmega48PB
m64 = ATmega64
m640 = ATmega640
m644 = ATmega644
m644a = ATmega644A
m644p = ATmega644P
m644pa = ATmega644PA
m644rfr2 = ATmega644RFR2
m645 = ATmega645
m6450 = ATmega6450
m649 = ATmega649
m6490 = ATmega6490
m64rfr2 = ATmega64RFR2
m8 = ATmega8
m8515 = ATmega8515
m8535 = ATmega8535
m88 = ATmega88
m88p = ATmega88P
m88pb = ATmega88PB
m8u2 = ATmega8U2
t10 = ATtiny10
t11 = ATtiny11
t12 = ATtiny12
t13 = ATtiny13
t13a = ATtiny13a
t15 = ATtiny15
t1634 = ATtiny1634
t167 = ATtiny167
t20 = ATtiny20
t2313 = ATtiny2313
t24 = ATtiny24
t25 = ATtiny25
t26 = ATtiny26
t261 = ATtiny261
t28 = ATtiny28
t4 = ATtiny4
t40 = ATtiny40
t4313 = ATtiny4313
t43u = ATtiny43u
t44 = ATtiny44
t441 = ATtiny441
t45 = ATtiny45
t461 = ATtiny461
t48 = ATtiny48
t5 = ATtiny5
t84 = ATtiny84
t841 = ATtiny841
t85 = ATtiny85
t861 = ATtiny861
t87 = ATtiny87
t88 = ATtiny88
t9 = ATtiny9
x128a1 = ATxmega128A1
x128a1d = ATxmega128A1revD
x128a1u = ATxmega128A1U
x128a3 = ATxmega128A3
x128a3u = ATxmega128A3U
x128a4 = ATxmega128A4
x128a4u = ATxmega128A4U
x128b1 = ATxmega128B1
x128b3 = ATxmega128B3
x128c3 = ATxmega128C3
x128d3 = ATxmega128D3
x128d4 = ATxmega128D4
x16a4 = ATxmega16A4
x16a4u = ATxmega16A4U
x16c4 = ATxmega16C4
x16d4 = ATxmega16D4
x16e5 = ATxmega16E5
x192a1 = ATxmega192A1
x192a3 = ATxmega192A3
x192a3u = ATxmega192A3U
x192c3 = ATxmega192C3
x192d3 = ATxmega192D3
x256a1 = ATxmega256A1
x256a3 = ATxmega256A3
x256a3b = ATxmega256A3B
x256a3bu = ATxmega256A3BU
x256a3u = ATxmega256A3U
x256c3 = ATxmega256C3
x256d3 = ATxmega256D3
x32a4 = ATxmega32A4
x32a4u = ATxmega32A4U
x32c4 = ATxmega32C4
x32d4 = ATxmega32D4
x32e5 = ATxmega32E5
x384c3 = ATxmega384C3
x384d3 = ATxmega384D3
x64a1 = ATxmega64A1
x64a1u = ATxmega64A1U
x64a3 = ATxmega64A3
x64a3u = ATxmega64A3U
x64a4 = ATxmega64A4
x64a4u = ATxmega64A4U
x64b1 = ATxmega64B1
x64b3 = ATxmega64B3
x64c3 = ATxmega64C3
x64d3 = ATxmega64D3
x64d4 = ATxmega64D4
x8e5 = ATxmega8E5
ucr2 = deprecated, use 'uc3a0512'
============================================ [FAILED] Took 2.81 seconds ============================================
ATmega16 FAILED 00:00:04.739
program_via_AVRISP_mkII FAILED 00:00:02.807
======================================= 2 failed, 0 succeeded in 00:00:07.546 =======================================
Part is -p
, Port is -P
. replace the second -p
with -P
. You can also see that in the documentation .
hi max,
I get BSOD and reset my PC after i change
-p
$BOARD_MCU
-P
$UPLOAD_PORT
propably problem with some sort of DLL.
