Hi @maxgerhardt,
I asked Paul to comment out those lines but it looks like he missed one, the upload_flags
That might account for why the command line looks doubled up on parameters.
Good catch on -p
versus -P
Cheers,
Norm.
Hi @maxgerhardt,
Good catch on -p
versus -P
Cheers,
Norm.
thanks again - here’s a screen clip of device manager and usb root properties, you can see the avrispmkII under Microchip Tools:
Sorry I wasn’t clear, I need you to open the “details” -> Hardware IDs view of the “AVRISP mkII” device.
This is good, the VID and PID are as expected.
I’m 99% sure that you’ve installed Atmel Studio and the drivers that have been installed with that are applied to the AVRISP mkII device. But avrdude
can’t work with those drivers, it needs it to be accessible with libUSB. Can you try as shown per point 4 of my second-previous post followed by a verbose upload? If libusb-win32
doesn’t work, try with libusbK and then WinUSB if the device isn’t already on WinUSB.
Note that this modifies which driver is loaded for that device. I’m not 100% sure on how to get back if you need the device for Atmel Studio again, but I think either the driver changes are reset when the USB device is plugged in and out again, or the original driver type is loaded with Zadig again, or the driver package in Atmel Studio is reinstalled.
thanks Max. yes you’re right about atmel studio. I’ll review your post and see what I can do. If I have the right idea, I’m just going to try to install a usb driver for the avrisp. The avrisp came with a cd and I guess there’ll be drivers on there. I didn’t use them because the instructions mentioned installation was automatic in atmel studio. It didn’t mention that it was for exclusive use by atmel studio…
I’ll see what I can do and post back.
best,
Paul
ok, I downloaded zadig and followed process. it successfully installed the libusb driver
I also reverted my platformio.ini as shown below, thanks for any further thoughts.
verbose compiler stuff:
PS C:\Users\Paul\Documents\PlatformIO\Projects\Blink-LED-AVR> C:\Users\Paul\.platformio\penv\Scripts\pio.exe run --target upload --verbose
Processing program_via_AVRISP_mkII (platform: atmelavr; board: ATmega328p; upload_protocol: custom; upload_port: usb; upload_flags: -C $PROJECT_PACKAGES_DIR/tool-avrdude/avrdude.conf, -p $BOARD_MCU, -P $UPLOAD_PORT, -c avrispmkII; upload_command: avrdude $UPLOAD_FLAGS -U flash:w:$SOURCE:i)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega328p.html
PLATFORM: Atmel AVR (3.1.0) > ATmega328P/PA
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 32KB Flash
Found 0 compatible libraries
MethodWrapper(["checkprogsize"], [".pio\build\program_via_AVRISP_mkII\firmware.elf"])
RAM: [ ] 0.0% (used 0 bytes from 2048 bytes)
Flash: [ ] 0.5% (used 178 bytes from 32768 bytes)
.pio\build\program_via_AVRISP_mkII\firmware.elf :
section size addr
.data 0 8388864
.text 178 0
.comment 48 0
.note.gnu.avr.deviceinfo 64 0
.debug_info 1524 0
.debug_abbrev 1442 0
.debug_line 26 0
.debug_str 520 0
Total 3802
<lambda>(["upload"], [".pio\build\program_via_AVRISP_mkII\firmware.hex"])
AVAILABLE: custom
CURRENT: upload_protocol = custom
avrdude "-C C:\Users\Paul\.platformio\packages/tool-avrdude/avrdude.conf" "-p atmega328p" "-P usb" "-c avrispmkII" -U flash:w:.pio\build\program_via_AVRISP_mkII\firmware.hex:i
avrdude: can't open config file " C:\Users\Paul\.platformio\packages/tool-avrdude/avrdude.conf": Invalid argument
avrdude: error reading system wide configuration file " C:\Users\Paul\.platformio\packages/tool-avrdude/avrdude.conf"
*** [upload] Error 1
================================================================================================== [FAILED] Took 0.57 seconds ==================================================================================================
platformio.ini:
;platformio configuration file saved from notepad
;[env:ATmega328]
;platform = atmelavr
;board = ATmega328p
[env:program_via_AVRISP_mkII]
board = ATmega328p
upload_protocol= custom
upload_port = usb
upload_flags =
-p $BOARD_MCU
-P $UPLOAD_PORT
-c avrispmkII
; -c stk500v2
It needs to be one value per line. Please try
board = ATmega328p
upload_port = usb
upload_flags =
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
avrispmkII
; -c stk500v2
If not revert back to the second-last platformio.ini
where had commented out the upload_command
great, it’s working, code uploaded and led blinking. Thanks very much for all your time Max and Norman, much appreciated.
best wishes,
Paul
