Hi, just used a more or less blank platformio.ini to re-burn the stock bootloader to my Arduino nano.
This worked fine, also fuse settings look good, BUT when setting the lock fuses, I got the following warning:
Maybe the standard lock fuse setting should be modified to mitigate the warning and possibly future errors. Should I create an issue already or could somebody reproduce?
If you add
board_bootloader.lock_bits = 0xCF
to the platformio.ini
the error is gone, yeah?
Then it’s that code that’s wrong
and it should be raised as an issue there.
Shouldn’t it be 0xFF
as no lock bit is used as per here? I’ll try both and let you know once I did it.
Ah, my Original Arduino boards.txt
says you’re right
Well, the answer is - partially. What I found out:
- both lock and unlock bits currently are deprecated, so the warning only goes away if I modify both.
- Too keep the same behavior as specified in the boards.txt, I have to have a look in the datasheet and boards.txt
Original from boards.txt:
nano.bootloader.unlock_bits=0x3F
nano.bootloader.lock_bits=0x0F
Error message says that unused bytes have to be written to 1
According to datasheet, unused bits are (the same for lock and unlock bit mask):
So, I add 12
to the first nibble and yield:
board_bootloader.unlock_bits = 0xEF
Result:
Warning gone. All fine. Will raise an issue.
