First time user trying to upload the Blink tutorial via PlatformIO IDE on Linux. A lot of things are already working but Upload is failing. The actual error is at the very bottom of this post. To clear up some questions here’s what’s already working:
Uploading via the Arduino programming environment works.
pio device monitor --port /dev/ttyUSB0 --baud 115200 - Works
One issue is that I can’t seem to set the baud rate for either Monitor or Upload. platformio.ini looks like this:
[env:feather32u4]
board = feather32u4
upload_speed = 115200 — changing upload speed has no effect
upload_port = /dev/ttyUSB0 — changing the port propagates through to the upload log
monitor_speed = 9600 — changing monitor speed has no effect
Below is the upload log with some redundant lines removed.
Building .pioenvs/feather32u4/firmware.hex
Checking size .pioenvs/feather32u4/firmware.elf
Configuring upload protocol…
AVAILABLE: avr109
Use manually specified: /dev/ttyUSB0
Forcing reset using 1200bps open/close on port /dev/ttyUSB0
Waiting for the new upload port…
Uploading .pioenvs/feather32u4/firmware.hex
Found programmer: Id = “hello f”; type = o
a butterfly/AVR109 but a AVR910 device?
*** [upload] Error 1
avrdude: error: buffered memory access not supported. Maybe it isn’t (line is truncated in log)
avrdude: initialization failed, rc=-1
