I am trying to upload a code i wrote in vscode with platformio, i have custom pcb with atmega168 and minicore bootloader, i can upload code to it through arduino ide no problem, but on platformio i get avrdude: Device signature = 0x000000 error, so it doesn’t even detect anything, port is 100% correct, my platformio.ini configuration is
[platformio]
default_envs = Upload_UART ; Default build target
; Common settings for all environments
[env]
; TARGET SETTINGS
; Chip in use
board = ATmega168P
; Clock frequency in [Hz]
board_build.f_cpu = 16000000L
; BUILD OPTIONS
; Comment out to enable LTO (this line unflags it)
build_unflags = -flto
; Extra build flags
; SERIAL MONITOR OPTIONS
; Serial monitor port defined in the Upload_UART environment
monitor_port = ${env:Upload_UART.upload_port}
; Serial monitor baud rate
; Run the following command to upload with this environment
; pio run -e Upload_UART -t upload
[env:Upload_UART]
; Serial bootloader protocol
upload_protocol = avrisp
; Serial upload port
upload_port = /dev/ttyUSB0
; Get upload baud rate defined in the fuses_bootloader environment
board_upload.speed = ${env:fuses_bootloader.board_bootloader.speed}
; pio run -e Upload_ISP -t upload
[env:Upload_ISP]
; Custom upload procedure
upload_protocol = custom
; Avrdude upload flags
upload_flags =
-C$PROJECT_PACKAGES_DIR/tool-avrdude/avrdude.conf
-p$BOARD_MCU
-PUSB
-cusbasp
; Avrdude upload command
; Run the following command to set fuses
; pio run -e fuses_bootloader -t fuses
; Run the following command to set fuses + burn bootloader
; pio run -e fuses_bootloader -t bootloader
[env:fuses_bootloader]
board_hardware.oscillator = external ; Oscillator type
board_hardware.uart = uart0 ; Set UART to use for serial upload
board_bootloader.speed = 115200 ; Set bootloader baud rate
board_hardware.bod = 4.3v ; Set brown-out detection
board_hardware.eesave = yes ; Preserve EEPROM when uploading using programmer
upload_protocol = avrisp ; Use the USBasp as programmer
upload_flags = ; Select USB as upload port and divide the SPI clock by 8
-PUSB
-B8
as written here
https://github.com/MCUdude/MiniCore/blob/master/PlatformIO.md just changed a few settings, any ideas what might be wrong?
