I have a problem with the programming of an ATMega1284 on a custom board. I wrote a simple code blink_led. After downloading it with the JTAG interface of the AVRDragon and running without debugging (“run without debugging”) nothing happen. run the program even without debugging. The JTAG RESET pin remains at low level (0.4V) . If I remove the JTAG connector then the program in the flash starts running and the LED blink as programmed.
My platformIO.ini file:
[env:bare_dragon]
board = ATmega1284
;framework = arduino
upload_protocol = dragon_jtag
board_build.f_cpu = 16000000L
upload_port = usb
board_upload.require_upload_port = false
upload_flags =
-e
-C
-v
-c
dragon_jtag
-p
m1284
-P
usb
How do I tell the programmer to put RESET high?
Thanks for your help
