Thanks for replying. My platformio.ini is as follows:
[env:uno]
board = uno
debug_tool = avr-stub
debug_port = /dev/ttyUSB1
lib_deps = jdolinay/avr-debugger@^1.5
I’ve found that adding
#include <app_api.h>
to main.cpp seems to find the other include files, so now onto the next error:
* The terminal process "platformio 'debug'" terminated with exit code: 1.
* Executing task in folder blinkpin: platformio debug
Processing uno (platform: atmelavr; board: uno; framework: arduino)
Removing unused dependencies...
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/__main__.py", line 102, in main
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1130, in __call__
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/cli.py", line 71, in invoke
return super().invoke(ctx)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1657, in invoke
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1404, in invoke
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 760, in invoke
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/click/decorators.py", line 26, in new_func
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/debug/cli.py", line 84, in cli
return _debug_in_project_dir(
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/debug/cli.py", line 111, in _debug_in_project_dir
return helpers.predebug_project(
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/debug/helpers.py", line 103, in predebug_project
ctx.invoke(
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/run/cli.py", line 144, in cli
process_env(
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/run/cli.py", line 201, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/run/processor.py", line 83, in process
install_project_env_dependencies(
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/commands/install.py", line 132, in install_project_env_dependencies
_install_project_env_libraries(project_env, options),
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/commands/install.py", line 204, in _install_project_env_libraries
_uninstall_project_unused_libdeps(project_env, options)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/commands/install.py", line 280, in _uninstall_project_unused_libdeps
lm.uninstall(spec)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/manager/_uninstall.py", line 29, in uninstall
return self._uninstall(spec, skip_dependencies)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/manager/_uninstall.py", line 34, in _uninstall
pkg = self.get_package(spec)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/manager/base.py", line 263, in get_package
spec = self.ensure_spec(spec)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/manager/base.py", line 133, in ensure_spec
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 184, in __init__
self._parse(self.raw)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 291, in _parse
raw = parser(raw)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 316, in _parse_requirements
self.requirements = tokens[1].strip()
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 231, in requirements
else semantic_version.SimpleSpec(str(value))
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/semantic_version/base.py", line 647, in __init__
self.clause = self._parse_to_clause(expression)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/semantic_version/base.py", line 1043, in _parse_to_clause
return cls.Parser.parse(expression)
File "/home/chris/.platformio/penv/lib/python3.10/site-packages/semantic_version/base.py", line 1063, in parse
raise ValueError("Invalid simple block %r" % block)
ValueError: Invalid simple block '~'
`pip install -U platformio` command
