Hi! I’m just starting with PlatformIO and I’m trying to use it to write code for ESP-01 module with 1MB of flash. I just created a new project using the esp01_1m board and it’s almost empty. However the build output reads:
DATA: [==== ] 36.3% (used 29754 bytes from 81920 bytes)
PROGRAM: [======= ] 73.9% (used 278664 bytes from 376832 bytes)
My concern here is with the total available PROGRAM space. Where is that 376832 bytes coming from? Shouldn’t say I have 1MB of total memory in the board?
Can you double check your board is specified as esp01_1m in your platformio.ini and that you aren’t using a different linker-script via a build flag? (i.e. using one of the other memory layouts provided)
I didn’t set any custom build flag. Also I don’t know what those .ld files are, so any link to learn about them is welcome!
What I can see is that these are all the .ld files I have in my .platformio directory, and none of them have the same name specified within the .json file. Do this mean something to you?
Hm… don’t know anything about that… I seem to remember people mentioning some partition.csv file, but that could be in relation to ESP-IDF or ESP32? You could try a stab in the dark, and try a different linker file… i.e. build_flags = -Wl,-Teagle.app.v6.new.1024.app1.ld … but it would be better to wait to see what others familar with esp8266-rtos-sdk have to say.
/* eagle.flash.bin @ 0x00000 */
/* eagle.irom0text.bin @ 0x20000 */
/* Flash Map, support 512KB/1MB/2MB/4MB SPI Flash */
/* |_flash.bin start(0x0000) |_irom0text.bin start(0x20000) | */
/* |_flash.bin end |_irom0text.bin end */
/* |_system param area(0x7b000) */
/* NOTICE: */
/* 1. You can change irom0 org, but MUST make sure irom0text.bin start not overlap flash.bin end. */
/* 2. You can change irom0 len, but MUST make sure irom0text.bin end not overlap system param area. */
/* 3. Space between flash.bin end and irom0text.bin start can be used as user param area. */
/* 4. Space between irom0text.bin end and system param area can be used as user param area. */
/* 5. Make sure irom0text.bin end < 0x100000 */
/* 6. system param area: */
/* 1>. 512KB--->0x07b000 */
/* 2>. 1MB----->0x0fb000 */
/* 3>. 2MB----->0x1fb000 */
/* 4>. 4MB----->0x3fb000 */
/* 7. Don't change any other seg. */
MEMORY
dport0_0_seg : org = 0x3FF00000, len = 0x10
dram0_0_seg : org = 0x3FFE8000, len = 0x18000
iram1_0_seg : org = 0x40100000, len = 0x8000
irom0_0_seg : org = 0x40220000, len = 0x5C000
INCLUDE "../ld/eagle.app.v6.common.ld"`
So in this flash layout your IROM0 space for the code has len = 0x5C000 aka 376832 bytes, which is exactly the message you’re getting.
