I have a confusion with clock sources / speeds and timers - I’m fairly new to PIO and Arduino.
I am using an ATtiny85.
I have the Arduino framework loaded so as to initialise stuff like millis() - I appreciate this uses Timer0. - I’ll need this for some debounce work later.
I want to use the SendOnlySoftwareSerial.h library for debug.
My problem is that I can only seem to get 2 PWM frequencies whatever the setting of the CS[13:10] bits in TCCR1 - either way too fast 245Hz or super slow at 1Hz.
I want to generate an inverted (I’ll be using P-MOSFET buffer) 50Hz PWM signal for a servo.
I can ‘fine tune’ the frequency by reducing the value of OCR1C down from 0xFF but starting at 1Hz, I can’t get an accurate 50Hz frequency and still have the necessary control of the pulse width using OCR1A.
Please see my code, PlatformIO.ini and some debug TTY output.
#ifndef F_CPU
#define F_CPU 8000000
#include <SendOnlySoftwareSerial.h>
#include <util/delay.h>
#include <avr/io.h> // pulls in (most of) the register and register bit names
#include <avr/interrupt.h> // so we can use interrupt vector names
#include <avr/sleep.h> // useful macros for putting the unit into sleep mode
#include <avr/wdt.h> // I changed the WDT so I can use it for measuring user inactivity
#include <avr/common.h> // added so SREG is a recognized register name - seems to be mission from <avr/io.h>
#define BAUD 9600
#define OCR1A_open 0x0F // PWM signal at 2ms
#define OCR1A_closed 0x07 // PWM signal at 1ms
//#define T1_CS13_CS10 (1<<CS13)|(1<<CS12)|(1<<CS11)|(1<<CS10) // 1Hz PWM on OC1A
//#define T1_CS13_CS10 (1<<CS13)|(0<<CS12)|(0<<CS11)|(0<<CS10) // 1Hz PWM on OC1A
//#define T1_CS13_CS10 (0<<CS13)|(1<<CS12)|(1<<CS11)|(1<<CS10) // 245Hz PWM on OC1A
//#define T1_CS13_CS10 (0<<CS13)|(1<<CS12)|(0<<CS11)|(0<<CS10) // 245Hz PWM on OC1A
#define T1_CS13_CS10 (0<<CS13)|(0<<CS12)|(0<<CS11)|(1<<CS10) // 245Hz PWM on OC1A
/* ATtiny85
PCINT5/-RESET/ACD0/dw PB5 1| u |8 VCC
PCINT3/XTAL1/CLKI/-OC1B/ADC3 PB3 2| |7 PB2 SCK/USCK/SCL/ADC1/T0/INT0/PCINT2
PCINT4/XTAL2/CLKO/OC1B/ADC2 PB4 3| |6 PB1 MISO/DO/AIN1/OC0B/OC1A/PCINT1
GND 4|___|5 PB0 MOSI/DI/SDA/AIN0/OC0A/-OC1A/AREF/PCINT0
PB0 - TTY (output)
PB1 - PWM (output)
PB2 - KEY (input)
PB3 - LDR (input)
PB4 - ENA (output)
PB5 - RESET (input)
#define TTY PB0
#define PWM PB1
#define KEY PB2
#define LDR PB3
#define ENA PB4
#define RESET PB5
SendOnlySoftwareSerial mySerial (TTY); // Tx pin
DDRB |= (1<<PWM)|(1<<TTY)|(1<<ENA); // define outputs
mySerial.begin(BAUD*2); // why do I need to do this?
mySerial.println(F("\n\r\n\rStarting"));
mySerial.println(F_CPU); // just to check what it's set to
// PWM using Timer0 on OC0B - but can't use this as I need millis() which uses Timer0
//OCR0A = 0x9C; //0x9C = 50Hz
//OCR0B = 20;
//TCCR0A |= (0<<COM0A1)|(0<<COM0A0)|(1<<COM0B1)|(1<<COM0B0)|(1<<WGM01)|(1<<WGM00);
//TCCR0B |= (1<<WGM02)|(1<<CS02)|(0<<CS01)|(1<<CS00);
// PWM using Timer1 (inverted only on OC1A - PB1)
//PLLCSR &= ~(1<<PCKE); // clearing this bit to force Synch clocking makes no difference
OCR1A = 0x09; // sets the duty cycle
OCR1C = 0xFF; // sets the TOP value ie frequency of PWM signal
TCCR1 |= (1<<PWM1A)|(1<<COM1A1)|(1<<COM1A0)|T1_CS13_CS10;
static unsigned long myMillis = millis();
static unsigned long counter = 0;
counter ++;
mySerial.print((counter));
mySerial.print(F(" "));
mySerial.println((myMillis));
//delay(500);
_delay_ms(500);
PORTB ^= (1<<ENA); // debug toggle an LED
See commented lines of #define T1_CS13_CS10
showing what values I used and the (lack of) change they made to the base PWM output frequency (My scope shows an inverted PWM signal on PB1)
I tried clearing the PCKE bit in the PLLCSR register to force synch clocking PLLCSR &= ~(1<<PCKE);
This had no effect.
PlatformIO.ini
[env:attiny85]
board = attiny85
; device is Pololu USBAVR Programmert v2.1
;upload_protocol = custom
;upload_port = COM5
;upload_flags =
; -C
; ; use "tool-avrdude-megaavr" for the atmelmegaavr platform
; ${platformio.packages_dir}/tool-avrdude/avrdude.conf
; -p
; $BOARD_MCU
; -P
; $UPLOAD_PORT
; -c
; stk500v2
;upload_command = avrdude $UPLOAD_FLAGS -U flash:w:$SOURCE:i
; device is USBASP V2.0 with updated firmware
upload_port = usb
upload_flags =
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
usbasp
; monitor set up
; You still need a TTY to USB convertor board
monitor_port = COM[3]
monitor_speed = 9600
TTY debug output
Starting
8000000
1 12
2 518
3 1026
4 1533
5 2041
6 2549
This confirms F_CPU is at 8000000. It also indicates that _delay_ms(500);
is accurately timed. When I used the Arduino delay(500);
this also generated an accurately timed delay when I tested this in code.
Here’s the PIO Upload dialog
* Executing task in folder MorseCode: C:\Users\Peter\.platformio\penv\Scripts\platformio.exe run --target upload
Processing attiny85 (platform: atmelavr; board: attiny85; framework: arduino)
----------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/attiny85.html
PLATFORM: Atmel AVR (3.4.0) > Generic ATtiny85
HARDWARE: ATTINY85 8MHz, 512B RAM, 8KB Flash
- framework-arduino-avr-attiny @ 1.5.2
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 10 compatible libraries
|-- SendOnlySoftwareSerial
Compiling .pio\build\attiny85\src\main.cpp.o
Linking .pio\build\attiny85\firmware.elf
Checking size .pio\build\attiny85\firmware.elf
RAM: [= ] 12.1% (used 62 bytes from 512 bytes)
Flash: [== ] 16.0% (used 1314 bytes from 8192 bytes)
Building .pio\build\attiny85\firmware.hex
AVAILABLE: custom
CURRENT: upload_protocol = custom
Uploading .pio\build\attiny85\firmware.hex
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file ".pio\build\attiny85\firmware.hex"
avrdude: writing flash (1314 bytes):
Writing | ################################################## | 100% 0.70s
avrdude: 1314 bytes of flash written
avrdude: verifying flash memory against .pio\build\attiny85\firmware.hex:
avrdude: load data flash data from input file .pio\build\attiny85\firmware.hex:
avrdude: input file .pio\build\attiny85\firmware.hex contains 1314 bytes
Reading | ################################################## | 100% 0.36s
avrdude: verifying ...
avrdude: 1314 bytes of flash verified
avrdude: safemode: Fuses OK (E:FE, H:DF, L:E2)
avrdude done. Thank you.
================================================== [SUCCESS] Took 5.30 seconds ==================================================
There must be something in the Arduino environment or something else I’m missing that is preventing me from generating a relatively slow PWM using Timer1 on OC1A.
I tried redefining the TCCR1 CS[13:10] bit values after every print statement just in case this was changing the timer1 settings - it made no difference.
I tried commenting out all the SendOnlySoftwareSerial statements just in case this library is changing Timer1 - this made no difference.
Are you able to aim me in the right direction?
Best regards
