Hello everyone.
I have problems programming my Attiny24.
I use an Arduino Nano as an ISP Programmer.
If i use the Arduino IDE with the code:
int ledPin = PB0;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
delay(1000);
digitalWrite(ledPin, HIGH);
delay(1000);
Everything works as expected.
But if i use the “same” code in VSC / PlatformIO:
int ledPin = PB0;
delay(1000);
delay(1000);
The Led does not blink.
Here is the output while programming:
Processing attiny24 (platform: atmelavr; board: attiny24; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/attiny24.html
PLATFORM: Atmel AVR (3.4.0) > Generic ATtiny24
HARDWARE: ATTINY24 8MHz, 128B RAM, 2KB Flash
- framework-arduino-avr-attiny @ 1.5.2
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 34 compatible libraries
Compiling .pio\build\attiny24\src\main.cpp.o
Linking .pio\build\attiny24\firmware.elf
Checking size .pio\build\attiny24\firmware.elf
RAM: [= ] 7.0% (used 9 bytes from 128 bytes)
Flash: [=== ] 30.0% (used 614 bytes from 2048 bytes)
Building .pio\build\attiny24\firmware.hex
AVAILABLE: stk500v1
CURRENT: upload_protocol = stk500v1
Looking for upload port...
Uploading .pio\build\attiny24\firmware.hex
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e910b (probably t24)
avrdude: erasing chip
avrdude: reading input file ".pio\build\attiny24\firmware.hex"
avrdude: writing flash (614 bytes):
Writing | ################################################## | 100% 1.29s
avrdude: 614 bytes of flash written
avrdude: verifying flash memory against .pio\build\attiny24\firmware.hex:
avrdude: load data flash data from input file .pio\build\attiny24\firmware.hex:
avrdude: input file .pio\build\attiny24\firmware.hex contains 614 bytes
Reading | ################################################## | 100% 0.53s
avrdude: verifying ...
avrdude: 614 bytes of flash verified
avrdude: safemode: Fuses OK (E:FF, H:DF, L:E2)
avrdude done. Thank you.
=============================================================================== [SUCCESS] Took 4.96 seconds ===============================================================================
I can see no issues. platformio.ini is:
[env:attiny24]
board = attiny24
board_build.mcu = attiny24
upload_flags =
-P$UPLOAD_PORT
-b$UPLOAD_SPEED
upload_port = COM26
upload_speed = 19200
board_build.f_cpu = 8000000L
board_fuses.lfuse = 0xE2
board_fuses.hfuse = 0xDF
board_fuses.efuse = 0xFF
Initially the fuses were set to 1Mhz but i was able set the fuses to 8Mhz with PlatformIO. Due to everything works with the Arduino IDE, it cannot be any hardware problem. It must be something in the settings of PlatformIO.
I was already able to program an Attiny85 with PlatformIO, no problems here. But the Attiny24 wont work…
Anyone has an idea?
