Recently I’ve been having trouble with pioplus causing a very high CPU load under certain conditions. The only way to stop this condition is to exit Atom.
My versions are:
Home 0.5.0
Core 3.5.0rc5
Atom 1.22.1
OSX 10.13.1 MBP 2016
The problem according to activity monitor is with Atom -> Atom Helper -> python -> pioplus
If I’m not logged into my pioplus account when I start Atom:
If I launch Atom and the Platformio Homepage automatically appears then the high cpu load starts and stays until I exit Atom.
If I uncheck Show at startup, and relaunch Atom there is no high cpu load until I launch the home page manually.
If I am logged into my pioplus account when I start Atom:
If I launch Atom and the Platformio Homepage appears then the high cpu load starts and stays until I exit Atom.
If I uncheck Show at startup, and relaunch Atom there is no high cpu load even when I launch the home page manually.
I don’t know why it matters if I’m logged into my PlatformIO account when I start Atom, or why it matters if the PlatformIO Homepage launches at startup, but it does seem to make a difference.
My workaround of not launching the homepage at startup is good enough for me, but the issue should be fixed.
Thanks.
