I have an ATMega8A with Minicore bootloader installed. it is 8MHZ internal. i can program the chip using UNO board and Arduino 2.2.1 IDE.
i am trying with VSCode / platformIO with below ini file:
[env:atmega8minicore8mhzinternal]
board = ATmega8
board_build.f_cpu = 8000000L
upload_protocol = arduino
board_upload.speed = 38400
but getting error as programmer not in sync.
Following is my verbose output. tried upload speed 9600, 19200, 57600 etc
Executing task in folder test: C:\Users\Toshiba.platformio\penv\Scripts\platformio.exe run --verbose --target upload --environment atmega8minicore8mhzinternal
Processing atmega8minicore8mhzinternal (platform: atmelavr; framework: arduino; board: ATmega8; board_build.f_cpu: 8000000L; upload_protocol: arduino; board_upload.speed: 38400; upload_flags: -e)
------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: …
PLATFORM: Atmel AVR (4.1.0) > ATmega8/A
HARDWARE: ATMEGA8 8MHz, 1KB RAM, 8KB Flash
DEBUG: Current (simavr) External (simavr)
- framework-arduino-avr-minicore @ 2.2.1
- tool-avrdude @ 1.70100.0 (7.1.0)
Found 8 compatible libraries
Scanning dependencies…
MethodWrapper([“checkprogsize”], [“.pio\build\atmega8minicore8mhzinternal\firmware.elf”])
RAM: [ ] 0.9% (used 9 bytes from 1024 bytes)
Flash: [ ] 3.7% (used 284 bytes from 7680 bytes)
.pio\build\atmega8minicore8mhzinternal\firmware.elf :
section size addr
.text 284 0
.data 0 8388704
.bss 9 8388704
.comment 17 0
.note.gnu.avr.deviceinfo 60 0
.debug_aranges 64 0
.debug_info 1538 0
.debug_abbrev 1142 0
.debug_line 258 0
.debug_str 378 0
Total 3750
avr-objcopy -O ihex -R .eeprom .pio\build\atmega8minicore8mhzinternal\firmware.elf .pio\build\atmega8minicore8mhzinternal\firmware.hex
([“upload”], [“.pio\build\atmega8minicore8mhzinternal\firmware.hex”])
AVAILABLE: arduino
BeforeUpload([“upload”], [“.pio\build\atmega8minicore8mhzinternal\firmware.hex”])
Auto-detected: COM6
avrdude -e -v -p atmega8 -C C:\Users\Toshiba.platformio\packages\tool-avrdude\avrdude.conf -c arduino -b 38400 -D -P COM6 -U flash:w:.pio\build\atmega8minicore8mhzinternal\firmware.hex:i
avrdude: Version 7.1-arduino.1
Copyright the AVRDUDE authors;
see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is {link not allowed}
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 38400
avrdude stk500_recv() error: programmer is not responding
avrdude stk500_getsync() warning: attempt 1 of 10: not in sync: resp=0x00
Since i can program the same chip using Arduino IDE, looks loke some ini is missing in PlatformIO. pl help…
