I’m trying to install the PlatformIO extension on my Raspberry Pi using a Remote SSH connection from VS.Code on my Windows machine.
Near the end of the installation I’m getting this error:
Error: Error: Compatible PlatformIO Core not found.
Reason: Could not run /home/pi/.platformio/penv/bin/platformio --help.
File "/home/pi/.platformio/penv/lib/python3.9/site-packages/platformio/project/helpers.py", line 74, in get_default_projects_dir
assert IS_WINDOWS
AssertionError
During handling of the above exception, another exception occurred:
File "/home/pi/.platformio/penv/bin/platformio", line 5, in <module>
from platformio.__main__ import main
File "/home/pi/.platformio/penv/lib/python3.9/site-packages/platformio/__main__.py", line 21, in <module>
from platformio import __version__, ...
I ran the installer script and got a confirmation the installation was successfull.
PlatformIO Core has been successfully installed into an isolated environment `/home/pi/.platformio/penv`!
The full path to `platformio.exe` is `/home/pi/.platformio/penv/bin/platformio`
If you need an access to `platformio.exe` from other applications, please install Shell Commands
(add PlatformIO Core binary directory `/home/pi/.platformio/penv/bin` to the system environment PATH variable):
See https://docs.platformio.org/page/installation.html#install-shell-commands
But when I start VS.Code, and activate the PIO extension the installer in VS.Code is running for a few minutes, and at the end I’m getting the exact same error as before.
