Assembler AVR Programming
Hello! Is there currently an option for full-fledged AVR programming on Assembler?
Indeed, this has been discussed in this forum here: Pure AVR Assembler programming.
By removing the framework = ... line in the platformio.ini, you essentially just have a bare-metal project and you can write .S assembly files which get processed by the avr-gcc -x assembler-with-cpp .. compiler
