Basic information: Win10x64, VScode,
, Arduino Uno.
When I try to upload my program to my Arduino Uno(it’s fine when compiling). It failed and give :
Tool Manager: Installing platformio/tool-avrdude @ ~1.60300.0
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\__main__.py", line 109, in main
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\click\core.py", line 829, in __call__
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\click\core.py", line 782, in main
rv = self.invoke(ctx)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\commands\__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\click\core.py", line 1259, in invoke
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\click\core.py", line 1066, in invoke
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\click\core.py", line 610, in invoke
return callback(*args, **kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\click\decorators.py", line 21, in new_func
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\commands\run\command.py", line 133, in cli
process_env(
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\commands\run\command.py", line 175, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\commands\run\processor.py", line 79, in process
result = p.run(build_vars, build_targets, self.silent, self.verbose, self.jobs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\platform\_run.py", line 60, in run
self.autoinstall_runtime_packages()
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\platform\_packages.py", line 74, in autoinstall_runtime_packages
self.pm.install(self.get_package_spec(name))
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 48, in install
pkg = self._install(
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 99, in _install
pkg = self.install_from_registry(spec, search_filters, silent=silent)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\package\manager\_registry.py", line 83, in install_from_registry
package = self.fetch_registry_package(spec)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\package\manager\_registry.py", line 144, in fetch_registry_package
result = regclient.get_package(self.pkg_type, spec.owner, spec.name)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\clients\registry.py", line 136, in get_package
return self.fetch_json_data(
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\clients\http.py", line 144, in fetch_json_data
response = self.send_request(method, path, **kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\util.py", line 73, in wrapper
return func(*args, **kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\clients\http.py", line 123, in send_request
return getattr(self._session, method)(path, **kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\requests\sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\platformio\clients\http.py", line 61, in request
return super(EndpointSession, self).request(
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\requests\sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\requests\sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\requests\adapters.py", line 439, in send
resp = conn.urlopen(
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\urllib3\connectionpool.py", line 696, in urlopen
self._prepare_proxy(conn)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\urllib3\connectionpool.py", line 964, in _prepare_proxy
conn.connect()
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\urllib3\connection.py", line 359, in connect
conn = self._connect_tls_proxy(hostname, conn)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\urllib3\connection.py", line 500, in _connect_tls_proxy
return ssl_wrap_socket(
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\urllib3\util\ssl_.py", line 432, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls)
File "c:\users\labourerlu\.platformio\penv\lib\site-packages\urllib3\util\ssl_.py", line 474, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock)
File "C:\Users\LabourerLu\.platformio\python3\lib\ssl.py", line 500, in wrap_socket
return self.sslsocket_class._create(
File "C:\Users\LabourerLu\.platformio\python3\lib\ssl.py", line 997, in _create
raise ValueError("check_hostname requires server_hostname")
ValueError: check_hostname requires server_hostname
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
终端进程“C:\Users\LabourerLu\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'”已终止,退出代码: 1。
终端将被任务重用,按任意键关闭。
> Executing task in folder TEST: C:\Users\LabourerLu\.platformio\penv\Scripts\platformio.exe run --target upload <
Processing uno (platform: atmelavr; board: uno; framework: arduino)
What can I do to upload my program successfully?
