I’m a more or less unexperienced user regarding C/C++ and new to PIO (with VS Code, Win 10).
In my current project I wanted to reuse some libs, which I successfuly used years ago in a (mainly) non-Arduino environment. What I can’t manage to track down is the cause of this linker error:
<artificial>:(.text.startup+0x100): undefined reference to `lcd_init(unsigned char)’
My platformio.ini is:
[env:Mission Cyrus III]
board = ATmega328P
lib_ldf_mode = chain+
libRK_utilities
libRK_I2C-master
libRK_PCF8574
libRK_LCD_I2C
Encoder
libRK_RC5-IR-Remote
;;build_flags =
;; -v -v
The library sources are installed in the global storage. When building the project, I get
> Executing task: C:\Users\LeftBrain\.platformio\penv\Scripts\platformio.exe run <
Processing Mission Cyrus III (platform: atmelavr; board: ATmega328P; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega328P.html
PLATFORM: Atmel AVR 2.0.0 > ATmega328P/PA
- framework-arduino-avr-minicore 2.0.3
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Found 14 compatible libraries
|-- <libRK_utilities> 0.0.1-alpha #3ac5d22
|-- <libRK_I2C-master> 0.0.1-alpha #c759d58
|-- <libRK_PCF8574> 0.0.1-alpha #149afb6
|-- <libRK_LCD_I2C> 0.0.1-alpha #fee99e6
|-- <Encoder> #4c4ec3a
|-- <libRK_RC5-IR-Remote> 0.0.1-alpha #e43375b
Compiling .pio\build\Mission Cyrus III\src\main.cpp.o
Compiling .pio\build\Mission Cyrus III\lib28d\libRK_utilities\libRK_utilities.c.o
Compiling .pio\build\Mission Cyrus III\lib195\libRK_I2C-master\libRK_I2C-master.c.o
Compiling .pio\build\Mission Cyrus III\lib55f\libRK_PCF8574\libRK_PCF8574.c.o
Archiving .pio\build\Mission Cyrus III\lib195\libRK_I2C-master.a
Archiving .pio\build\Mission Cyrus III\lib55f\libRK_PCF8574.a
Archiving .pio\build\Mission Cyrus III\lib28d\libRK_utilities.a
Compiling .pio\build\Mission Cyrus III\libc51\libRK_LCD_I2C\libRK_LCD_I2C.c.o
Compiling .pio\build\Mission Cyrus III\lib1cc\Encoder\Encoder.cpp.o
Compiling .pio\build\Mission Cyrus III\lib7bf\libRK_RC5-IR-Remote\libRK_RC5-IR-Remote.cpp.o
Archiving .pio\build\Mission Cyrus III\libFrameworkArduinoVariant.a
Compiling .pio\build\Mission Cyrus III\FrameworkArduino\CDC.cpp.o
Archiving .pio\build\Mission Cyrus III\libc51\libRK_LCD_I2C.a
Archiving .pio\build\Mission Cyrus III\lib1cc\libEncoder.a
Archiving .pio\build\Mission Cyrus III\lib7bf\libRK_RC5-IR-Remote.a
Compiling .pio\build\Mission Cyrus III\FrameworkArduino\HardwareSerial.cpp.o
[...more FrameworkArduino stuff here...]
Compiling .pio\build\Mission Cyrus III\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\Mission Cyrus III\libFrameworkArduino.a
Linking .pio\build\Mission Cyrus III\firmware.elf
C:\Users\LEFTBR~1\AppData\Local\Temp\ccezMMdQ.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x100): undefined reference to `lcd_init(unsigned char)'
<artificial>:(.text.startup+0x10e): undefined reference to `lcd_home()'
[...some more of these...]
*** [.pio\build\Mission Cyrus III\firmware.elf] Error 1
The dependency graph looks fine, the function declarations/definitions in question are in libRK_LCD_I2C.h / libRK_LCD_I2C.c like:
In libRK_LCD_I2C.h:
#include <inttypes.h>
#include <stdbool.h>
#include <avr/pgmspace.h>
extern bool lcd_init( uint8_t dispAttr);
extern void lcd_home( void);
In libRK_LCD_I2C.c:
#include "libRK_PCF8574.h" // this lib contains all the I2C stuff
An objdump on the lib archive file yields:
libRK_LCD_I2C.c.o: file format elf32-avr
SYMBOL TABLE:
00000000 l df *ABS* 00000000 libRK_LCD_I2C.c
00000000 l d .gnu.lto_lcd_home.e5da2ecd 00000000 .gnu.lto_lcd_home.e5da2ecd
00000000 l d .gnu.lto_lcd_init.e5da2ecd 00000000 .gnu.lto_lcd_init.e5da2ecd
Well, here I’m stuck :-o
Any idea what’s going wrong?
Btw.: even with
-v -v
in platformio.ini I do not see the call to ld.exe in the terminal log. Is there a possibility to force PIO to “echo” the complete linker command? Or… am I just too stupid to find it??
Appreciate your help
Ralph
