So I have a very wierd behavior using two different ArduinoJson objects. I was not able to reproduce it in a small example but could track it down to some extent.
From MQTT I receive a json string payload
looking like this:
{"getLog": {"BOOL": false}, "restartESP": {"BOOL": false}, "config": {"M": {"cRI": {"N": "1200000"}, "cST": {"N": "120000"}, "SSID": {"S": "smartabell"}, "cAL": {"BOOL": true}, "PW": {"S": "smartabell"}}}, "OTA": {"S": "99"}, "time": {"S": ""}, "updateConfig": {"BOOL": false}, "MAC": {"S": "84:CC:A8:00:E7:94"}}
I store it in
DynamicJsonDocument mqttJsonDoc(MY_MQTT_MAX_PACKET_SIZE);
deserializeJson(mqttJsonDoc, payload);
for further parsing, which works fine at the beginning. However, when I call this function to ACK the MQTT package (it is called in the same function where mqttJsonDoc
is created):
bool ackDDBAction(const char *new_val, const char *ack_pub_topic)
/* JSON settings */
DynamicJsonDocument ackJsonDoc(MQTT_MAX_ACK_SIZE);
ackJsonDoc["MAC"] = MAC_str;
ackJsonDoc["ACK"] = "";
ackJsonDoc["updateConfig"] = new_val;
/* Calculate buffer length */
size_t jsonSize = measureJson(ackJsonDoc) + 1;
char jsonBuffer[jsonSize];
/* Serialize json object into a char array */
serializeJson(ackJsonDoc, jsonBuffer, jsonSize);
/* Send ack */
ack_success = client.publish(ack_pub_topic, jsonBuffer);
return ack_success;
Somehow my original json object mqttJsonDoc
is corrupted and looks like:
{"getLog":{"BOOL":false},"restartESP":{"BOOL":false},"config":{"M":{"cRI":{"N":"1200000"},"cST":{"N":"120000"},"SSID":{"S":"smartabell"},"cAL":{"BOOL":true},"PW":{"S":"smartabell"}}},"OTA":{"S":"99"},"time":{"S":""},"updateConfig":{"BOOL":false},"MAC":{"S":"84:CC:A8:00:E7:94"}}{"ub{\"MAC\":\"84CCA800E794\",\"ACK\":\"\",\"getLog\":\"0\"}0000":{"\":\"84CCA800E794\",\"ACK\":\"\",\"getLog\":\"0\"}0000":false},"CCA800E794\",\"ACK\":\"\",\"getLog\":\"0\"}0000":{",\"ACK\":\"\",\"getLog\":\"0\"}0000":false},"\":\"\",\"getLog\":\"0\"}0000":{"etLog\":\"0\"}0000":{"Log\":\"0\"}0000":{":\"0\"}0000":"0\"}0000"},"cST":{"N":"120000"},"SSID":{"S":"smartabell"},"cAL":{"BOOL":true},"PW":{"S":"smartabell"}}},"OTA":{"S":"99"},"time":{"S":""},"updateConfig":{"BOOL":false},"MAC":{"S":"84:CC:A8:00:E7:94"}}
The beginning is similar, but in the middle, fragments of the other jsonDocument ackJsonDoc
appear. Besides, it is full of escape chars \
. After some debugging, I found out that only when the line serializeJson(ackJsonDoc, jsonBuffer, jsonSize);
is executed mqttJsonDoc
gets corrupted.
I played around with dynamic and static json document but it didnt change the behavior, besides out of curiosity, I created another json object to see if somehow there was a memory overlap.
DynamicJsonDocument mqttJsonDoc2(MY_MQTT_MAX_PACKET_SIZE);
deserializeJson(mqttJsonDoc2, payload);
But this additional dynamic json document holding the payload as well, is corrupted when ackDDBAction()
is called. Increasing any of the json objects by size did not lead to an improvement as well.
I was looking for known issues and cavities but didnt find anything in the documentation serializeJson() | ArduinoJson 6.
But maybe someone has an idea or faced this issue before - I could do some work arounds but they would be ugly and I would like to understand what is happening here.
