Like others here I’m trying to replace the Arduino IDE with Platform.io for better development of libraries and particularly so I can debug. I’m working with an Arduino Zero (this one) with the built-in EDBG debug chip.
In case it’s relevant, I also spent some time (unsuccessfully) trying to get Atmel Studio 7 to program this Arduino. In the process I seemed to blow away the bootloader. I used the Arduino IDE to re-burn the bootloader.
I’m testing with the ubiquitous blink program.
#include "Arduino.h"
pinMode(LED_BUILTIN, OUTPUT);
delay(500);
delay(500);
From the Arduino IDE, I can successfully upload and run the sketch as expected (after removing the first #include line)
However, when I switch over to platform.io, I get the following when I build and run.
[Mon Aug 7 13:03:02 2017] Processing zero (platform: atmelsam; board: zero; framework: arduino)
Collected 7 compatible libraries
Looking for dependencies...
Project does not have dependencies
Linking .pioenvs/zero/firmware.elf
Checking program size
text data bss dec hex filename
9448 256 1780 11484 2cdc .pioenvs/zero/firmware.elf
Uploading .pioenvs/zero/firmware.bin
GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00135-g80299198 (2017-06-22-18:37)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
none separate
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 03.22.01B3
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 400 kHz
Info : SWD DPIDR 0x0bc11477
Info : at91samd21g18.cpu: hardware has 4 breakpoints, 2 watchpoints
xPSR: 0x81000000 pc: 0x00000614 msp: 0x20007ffc
** Programming Started **
auto erase enabled
Info : SAMD MCU: SAMD21G18A (256KB Flash, 32KB RAM)
Warn : Adding extra erase range, 00000000 to 0x00001fff
wrote 24576 bytes from file .pioenvs/zero/firmware.bin in 2.411482s (9.952 KiB/s)
** Programming Finished **
** Verify Started **
verified 9704 bytes in 0.820003s (11.557 KiB/s)
** Verified OK **
** Resetting Target **
**Error: at91samd21g18.cpu -- clearing lockup after double fault**
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x61000003 pc: 0xfffffffe msp: 0xffffffd8
shutdown command invoked
========================= [SUCCESS] Took 5.14 seconds =========================
- Despite the “Success” message, the sketch does not run (as expected with the Error line showing the lockup after double fault.
Also not sure why there is the line “Info : at91samd21g18.cpu: hardware has 4 breakpoints, 2 watchpoints”. Could these have been added by Atmel Studio and not removed? I’ve unsuccessfully tried to run the platform.io debugger but didn’t get anywhere near adding breakpoints.
Furthermore, if I go back to the Arduino IDE and try to Upload the sketch it reports the same lockup/double fault error, and I cannot proceed until I re-burn the bootloader.
Happy to provide any further log dumps as needed to diagnose.
Thanks for any help.
