Hello, I got this error: error: ‘EEPROM’ was not declared in this scope on this line:
#include <EEPROM.h>
buffer[i]=EEPROM.read(readAddress++);
The EEPROM.h is already installed in the Build-in libraries. Any idea what is wrong?
Thank you in advance!
Full platformio.ini
and code please.
[env:uno]
board = uno
monitor_speed = 57600
All examples gives an error on EEPROM
#include <EEPROM.h>
int addr = 0;
void setup() {}
int val = analogRead(0) / 4;
EEPROM.write(addr, val);
addr = addr + 1;
if (addr == EEPROM.length()) {
addr = 0;
delay(100);
What’s the exact output of the “Build” project task?
src/Flube.cpp: In function 'void loop()':
src/Flube.cpp:11:3: error: 'EEPROM' was not declared in this scope
src/Flube.cpp:11:3: note: suggested alternative: 'EECR'
EECR
Compiling .pio/build/uno/FrameworkArduino/WString.cpp.o
Compiling .pio/build/uno/FrameworkArduino/abi.cpp.o
*** [.pio/build/uno/src/Flube.cpp.o] Error 1
Compiling .pio/build/uno/FrameworkArduino/hooks.c.o
I see.
So, on my machine the code builds fine.
Linking .pio\build\uno\firmware.elf
Checking size .pio\build\uno\firmware.elf
RAM: [ ] 0.5% (used 11 bytes from 2048 bytes)
Flash: [ ] 2.2% (used 720 bytes from 32256 bytes)
Building .pio\build\uno\firmware.hex
============================== [SUCCESS] Took 2.66 seconds ==============================
Please do the following:
- remove all folders in
C:\Users\<user>\.platformio\.cache
C:\Users\<user>\.platformio\lib
- remove the folder
C:\Users\<user>\.platformio\packages\framework-arduino-avr
- remove the (hidden)
.pio
folder in the project - build again
Same error
Tool Manager: Installing platformio/framework-arduino-avr @ ~5.1.0
Tool Manager: framework-arduino-avr@5.1.0 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (4.0.1) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.1.0
Found 6 compatible libraries
|-- FastLED @ 3.5.0
|-- EEPROM @ 2.0
Compiling .pio/build/uno/src/main.cpp.o
Compiling .pio/build/uno/FrameworkArduino/wiring_analog.c.o
Compiling .pio/build/uno/FrameworkArduino/wiring_digital.c.o
Compiling .pio/build/uno/FrameworkArduino/wiring_pulse.S.o
Compiling .pio/build/uno/FrameworkArduino/wiring_pulse.c.o
src/main.cpp: In function 'void loop()':
src/main.cpp:11:3: error: 'EEPROM' was not declared in this scope
src/main.cpp:11:3: note: suggested alternative: 'EECR'
EECR
Compiling .pio/build/uno/FrameworkArduino/wiring_shift.c.o
*** [.pio/build/uno/src/main.cpp.o] Error 1
======================================================================= [FAILED] Took 4.87 seconds =======================================================================
* The terminal process "platformio 'run', '--environment', 'uno'" terminated with exit code: 1.
How does FastLED come into the equation here? I have feeling you’re suddendly using a either different platformio.ini or code than shown above.
Fastled is installed because I will need it for this projet. Without it, I have the same issue
Now the example is compiling but I still have the issue in my code. I’m digging.
I was using an ESP32. There is no eeprom on such processor!
The ESP32 Arduino core does have an EEPROM class which uses Flash to emulate EEPROM. This works nicely.
