Hi, I have developed a custom bootload using Renesas e2 Studio, now the boot is not 0x4000 in size but 0x8000, how to change in platformio the base flash address to 0x8000 and the flash size to 0x38000 for Arduino framework ?
Regards
GMG
Regards
GMG
As you can see in
These addresses are hardcoded into the files.
If everything else for that variant stays the same, you can just repoint the linkerscript to your own one, as is possible by setting
board_build.ldscript = own_linker.ld
E.g. with content
Linker File for Renesas FSP
/* generated memory regions file - do not edit */
RAM_START = 0x20000000;
RAM_LENGTH = 0x8000;
FLASH_START = 0x00000000;
FLASH_LENGTH = 0x40000;
DATA_FLASH_START = 0x40100000;
DATA_FLASH_LENGTH = 0x2000;
OPTION_SETTING_START = 0x00000000;
OPTION_SETTING_LENGTH = 0x0;
OPTION_SETTING_S_START = 0x00000000;
OPTION_SETTING_S_LENGTH = 0x0;
ID_CODE_START = 0x01010018;
ID_CODE_LENGTH = 0x20;
SDRAM_START = 0x90000000;
SDRAM_LENGTH = 0x0;
QSPI_FLASH_START = 0x60000000;
QSPI_FLASH_LENGTH = 0x0;
OSPI_DEVICE_0_START = 0x68000000;
OSPI_DEVICE_0_LENGTH = 0x0;
OSPI_DEVICE_1_START = 0x70000000;
OSPI_DEVICE_1_LENGTH = 0x0;
/* CHANGE FLASH START */
FLASH_IMAGE_START = 0x8000;
VECTOR_TABLE_LENGTH = 0x100;
BSP_CFG_STACK_MAIN_BYTES = 0x400;
/* Define memory regions. */
MEMORY
FLASH (rx) : ORIGIN = FLASH_IMAGE_START, LENGTH = FLASH_LENGTH - FLASH_IMAGE_START
RAM (rwx) : ORIGIN = RAM_START, LENGTH = RAM_LENGTH
DATA_FLASH (rx) : ORIGIN = DATA_FLASH_START, LENGTH = DATA_FLASH_LENGTH
OPTION_SETTING (r): ORIGIN = OPTION_SETTING_START, LENGTH = OPTION_SETTING_LENGTH
OPTION_SETTING_S (r): ORIGIN = OPTION_SETTING_S_START, LENGTH = OPTION_SETTING_S_LENGTH
ID_CODE (rx) : ORIGIN = ID_CODE_START, LENGTH = ID_CODE_LENGTH
/* Library configurations */
GROUP(libgcc.a libc.a libm.a libnosys.a)
/* Linker script to place sections and symbol values. Should be used together
* with other linker script that defines memory regions FLASH and RAM.
* It references following symbols, which must be DEFINED in code:
* Reset_Handler : Entry of reset handler
* It defines following symbols, which code can use without definition:
* __exidx_start
* __exidx_end
* __copy_table_start__
* __copy_table_end__
* __zero_table_start__
* __zero_table_end__
* __etext
* __data_start__
* __preinit_array_start
* __preinit_array_end
* __init_array_start
* __init_array_end
* __fini_array_start
* __fini_array_end
* __data_end__
* __bss_start__
* __bss_end__
* __HeapLimit
* __StackLimit
* __StackTop
* __stack
* __Vectors_End
* __Vectors_Size
* __qspi_flash_start__
* __qspi_flash_end__
* __qspi_flash_code_size__
* __qspi_region_max_size__
* __qspi_region_start_address__
* __qspi_region_end_address__
* __ospi_device_0_start__
* __ospi_device_0_end__
* __ospi_device_0_code_size__
* __ospi_device_0_region_max_size__
* __ospi_device_0_region_start_address__
* __ospi_device_0_region_end_address__
* __ospi_device_1_start__
* __ospi_device_1_end__
* __ospi_device_1_code_size__
* __ospi_device_1_region_max_size__
* __ospi_device_1_region_start_address__
* __ospi_device_1_region_end_address__
ENTRY(Reset_Handler)
SECTIONS
.text :
__tz_FLASH_S = ABSOLUTE(FLASH_START);
__ROM_Start = .;
/* .sketch_boot section supports the Arduino SxU libraries, which are second stage bootloaders.
* The bootloaded sketch then starts aligned at next flash page after the SxU */
KEEP(*(.sketch_boot))
. = ALIGN(0x800);
/* Even though the vector table is not 256 entries (1KB) long, we still allocate that much
* space because ROM registers are at address 0x400 and there is very little space
* in between. */
KEEP(*(.fixed_vectors*))
KEEP(*(.application_vectors*))
__Vectors_End = .;
*(.text*)
KEEP(*(.version))
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*crtbegin?.o(.ctors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*crtbegin?.o(.dtors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.rodata*)
KEEP(*(.eh_frame*))
__ROM_End = .;
} > FLASH = 0xFF
__Vectors_Size = __Vectors_End - __Vectors;
.ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > FLASH
__exidx_start = .;
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > FLASH
__exidx_end = .;
/* To copy multiple ROM to RAM sections,
* uncomment .copy.table section and,
* define __STARTUP_COPY_MULTIPLE in startup_ARMCMx.S */
.copy.table :
. = ALIGN(4);
__copy_table_start__ = .;
LONG (__etext)
LONG (__data_start__)
LONG (__data_end__ - __data_start__)
LONG (__etext2)
LONG (__data2_start__)
LONG (__data2_end__ - __data2_start__)
__copy_table_end__ = .;
} > FLASH
/* To clear multiple BSS sections,
* uncomment .zero.table section and,
* define __STARTUP_CLEAR_BSS_MULTIPLE in startup_ARMCMx.S */
.zero.table :
. = ALIGN(4);
__zero_table_start__ = .;
LONG (__bss_start__)
LONG (__bss_end__ - __bss_start__)
LONG (__bss2_start__)
LONG (__bss2_end__ - __bss2_start__)
__zero_table_end__ = .;
} > FLASH
__etext = .;
__tz_RAM_S = ORIGIN(RAM);
/* If DTC is used, put the DTC vector table at the start of SRAM.
This avoids memory holes due to 1K alignment required by it. */
.fsp_dtc_vector_table (NOLOAD) :
. = ORIGIN(RAM);
*(.fsp_dtc_vector_table)
} > RAM
/* Initialized data section. */
.data :
__data_start__ = .;
. = ALIGN(4);
__Code_In_RAM_Start = .;
KEEP(*(.code_in_ram*))
__Code_In_RAM_End = .;
*(vtable)
/* Don't use *(.data*) because it will place data meant for .data_flash in this section. */
*(.data.*)
*(.data)
. = ALIGN(4);
/* preinit data */
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP(*(.preinit_array))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(4);
/* init data */
PROVIDE_HIDDEN (__init_array_start = .);
KEEP(*(SORT(.init_array.*)))
KEEP(*(.init_array))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(4);
/* finit data */
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP(*(SORT(.fini_array.*)))
KEEP(*(.fini_array))
PROVIDE_HIDDEN (__fini_array_end = .);
KEEP(*(.jcr*))
. = ALIGN(4);
/* All data end */
__data_end__ = .;
} > RAM AT > FLASH
.noinit (NOLOAD):
. = ALIGN(4);
__noinit_start = .;
KEEP(*(.noinit*))
. = ALIGN(8);
/* Place the FreeRTOS heap here so that the __HeapLimit calculation does not include the freertos heap. */
KEEP(*(.heap.*))
__noinit_end = .;
} > RAM
.bss :
. = ALIGN(4);
__bss_start__ = .;
*(.bss*)
*(COMMON)
. = ALIGN(4);
__bss_end__ = .;
} > RAM
.heap (NOLOAD):
. = ALIGN(8);
__HeapBase = .;
end = .;
KEEP(*(.heap))
} > RAM
__StackTop = ORIGIN(RAM) + LENGTH(RAM) - VECTOR_TABLE_LENGTH;
/* .stack_dummy section doesn't contains any symbols. It is only
* used for linker to calculate size of stack sections, and assign
* values to stack symbols later */
.stack_dummy ABSOLUTE(__StackTop - BSP_CFG_STACK_MAIN_BYTES) (NOLOAD):
. = ALIGN(8);
__HeapLimit = .;
__StackLimit = .;
KEEP(*(.stack))
KEEP(*(.stack*))
__StackTopAll = .;
} > RAM
.vector_table ABSOLUTE(__StackTop) (NOLOAD):
. = ALIGN(4);
APPLICATION_VECTOR_TABLE_ADDRESS_RAM = .;
. = ABSOLUTE(RAM_START + RAM_LENGTH);
} > RAM
PROVIDE(__stack = __StackTop);
.ns_buffer (NOLOAD):
KEEP(*(.ns_buffer*))
} > RAM
/* Data flash. */
.data_flash :
. = ORIGIN(DATA_FLASH);
__tz_DATA_FLASH_S = .;
__Data_Flash_Start = .;
KEEP(*(.data_flash*))
__Data_Flash_End = .;
__tz_DATA_FLASH_N = ALIGN(1024);
} > DATA_FLASH
/* Note: There are no secure/non-secure boundaries for ID_CODE. These symbols are provided for the RA configuration tool. */
__tz_ID_CODE_S = ORIGIN(ID_CODE);
.id_code :
__ID_Code_Start = .;
KEEP(*(.id_code*))
__ID_Code_End = .;
} > ID_CODE
__tz_ID_CODE_N = __ID_Code_End;
/* Symbol required for RA Configuration tool. */
__tz_OPTION_SETTING_S = ORIGIN(OPTION_SETTING);
.option_setting :
__OPTION_SETTING_Start = .;
KEEP(*(.option_setting_ofs0))
. = __OPTION_SETTING_Start;
KEEP(*(.option_setting_dualsel))
KEEP(*(.option_setting_sas))
__OPTION_SETTING_End = .;
} > OPTION_SETTING = 0xFF
.option_setting_ns :
__OPTION_SETTING_NS_Start = .;
KEEP(*(.option_setting_ofs1))
. = __OPTION_SETTING_NS_Start;
KEEP(*(.option_setting_banksel))
KEEP(*(.option_setting_bps0))
KEEP(*(.option_setting_bps1))
KEEP(*(.option_setting_bps2))
KEEP(*(.option_setting_pbps0))
KEEP(*(.option_setting_pbps1))
KEEP(*(.option_setting_pbps2))
__OPTION_SETTING_NS_End = .;
__tz_OPTION_SETTING_S_S = ORIGIN(OPTION_SETTING_S);
.option_setting_s :
__OPTION_SETTING_S_Start = .;
KEEP(*(.option_setting_ofs1_sec))
. = __OPTION_SETTING_S_Start;
KEEP(*(.option_setting_banksel_sec))
KEEP(*(.option_setting_bps_sec0))
KEEP(*(.option_setting_bps_sec1))
KEEP(*(.option_setting_bps_sec2))
KEEP(*(.option_setting_pbps_sec0))
KEEP(*(.option_setting_pbps_sec1))
KEEP(*(.option_setting_pbps_sec2))
KEEP(*(.option_setting_ofs1_sel))
KEEP(*(.option_setting_banksel_sel))
KEEP(*(.option_setting_bps_sel0))
KEEP(*(.option_setting_bps_sel1))
KEEP(*(.option_setting_bps_sel2))
__OPTION_SETTING_S_End = .;
} > OPTION_SETTING_S = 0xFF
__tz_OPTION_SETTING_S_N = __OPTION_SETTING_S_End;
To further influce the loading address used for some upload protocols (“DFU” not being one of them) here, you can additionally add
board_upload.offset_address = 0x8000
to the platformio.ini
I know this workaround, but I was looking for a nicer solution without having to modify software that will be re-modified with every update.
Then there is none.
You would have to file an issue agains https://github.com/arduino/ArduinoCore-renesas so that the flash start address becomes a linker-defined variable (-Wl,--defsym flash_start=...
or something like that), so that PlatformIO can change it more cleanly.
Plus, you should fixate the platform version for platform = renesas@...
anyways. So there’s no possible variation in terms of the framework version. This should be pretty stable.
